Headlight help (led) - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 06-14-2018, 06:54 PM Thread Starter
Year/Make/Model: 1989 kawasaki vulcan, 2003 kawasaki vulcan, 2006 harley deuce
Displacement/CC's: 750, 800, 1450
Color: ?, red, brandy wine sunglow
I am looking for a little help. My son has a 800 Classic And i think his headlight is lacking. I would like to buy him a led headlight to brighten the road. I run a daymaker on my harley and would ideally like something comparable. Has anyone here done a swap and if so what is involved? Was it plug and play? And we’re results good?
Nhsmoker is offline
post #2 of 5 (permalink) Old 06-14-2018, 07:18 PM Thread Starter
Apparently i posted a similar question last year and bulbs were kind of the answer but what i am really looking for is a good sealed unit that has a more defined beam, Is this possible?I feel a led bulb will more randomly throw the light and may possibly blind oncoming traffic but will losten to thoughts
Nhsmoker is offline
post #3 of 5 (permalink) Old 06-16-2018, 01:13 PM
Currently using Safego Motorcycle H4 LED Headlight Bulb H/L High Low Dual Beam 20W 2000lm Motorbike H4 LED Lights Kit M4-H4 which I find is better than 100 watt halogen bulb. Only thing I don't like is that only the tol half of the headlight is lit. The 100 watt bulb I found started melting my connector. Thought about trying different H4 led bulbs and retrofitting a daymaker but for now decided save that money. I'm okay with what I'm using currently. Hoping this helps a little.
1996 800A
gun4u2 is offline
post #4 of 5 (permalink) Old 06-16-2018, 08:49 PM Thread Starter
Could i just buy a harley housing and a daymaker for a harley?
Nhsmoker is offline
post #5 of 5 (permalink) Old 06-18-2018, 12:18 AM
Beans's Avatar
Year/Make/Model: 2005 Vulcan 800 Classic
I would wager a guess that if you bought a Harley housing and headlight to go with it you could totally use it, as long as you can find a way to mount it. You may need to get some headlight brackets that mount onto the fork stanchions. It would also be a good idea to check the wattage to check that you won't be drawing too many amps, though with LEDs I doubt that would be an issue. The last issue I can think of is the electrical connector, it may not be the same.
Never argue with a fool: onlookers may not be able to tell the difference.
Beans is offline
Super Bright LED 2 inch 10 watt LED auxiliary light Rhyno General Vulcan Talk 3 06-22-2013 07:01 PM
LED headlight keymankirk Wrench Heads 13 06-06-2013 08:28 AM
LED turn signal with LED license frame needs load equalizer ? evodog Vulcan 900 20 07-12-2012 07:20 AM
led headlight muggs General Vulcan Talk 1 11-14-2011 10:36 PM
