Bike was running fine a week ago... I need some advice - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 06-14-2018, 10:25 AM Thread Starter
Arzante's Avatar
So I just bought my Vulcan 800 3 weeks ago. I've been running it once a week. I've been excited to get a new tire on it and actually ride it. We hauled it to the bike shop. I tried to crank it up and smoke came out of the exhaust pipes. It would idle for maybe 5 seconds and die. I checked the petcock and saw it was in prime. It also seemed low on gas. I filled it up and same problem. Also, gas is leaking out of the hypercharger. Any ideas on where to start?
Arzante is offline
post #2 of 5 (permalink) Old 06-14-2018, 10:40 AM
bearslayer's Avatar
Year/Make/Model: 2004 Nomad , 1985 BMW K100 X2 , 1985 Intruder, 1998 Ducati Monster, 1972 CL350, 1948 Indian CZ125, 2
Displacement/CC's: 125 -1500
Color: Blue & Silver , Black , Gray , Maroon,black,
would first check the oil for fuel contamination. If bike is not fuel injected fuel some times runs through the carbs and into the cylinders. It can drain past the rings into the crankcase. If this has occurred I would do an oil change. Removing the spark plugs will let any accumulated fuel evaporate. However if you scoot is fuel injected this is all academic.
That which does not kill me tends to really piss me off.
bearslayer is online now
post #3 of 5 (permalink) Old 07-12-2018, 12:15 PM Thread Starter
Arzante's Avatar
I did the same thing. I bet your petcock was left on prime. It allows all the gas to flow into the oil pan. Drain all the gas/oil from the oil pan and fill it back up with oil. Let the oil in the engine burn off at idle. It will take about an hour
Arzante is offline
post #4 of 5 (permalink) Old 07-30-2018, 02:11 PM
texasgrape's Avatar
Year/Make/Model: 1996 Kawasaki Vulcan 800 Classic
Displacement/CC's: 800
Color: Blue-Green
I am confused; Arzante you answered this question like someone else; did you find the problem? Petcock?
1996 Vulcan 800, Blue/Green
JUST SOLD: 2016 Indian Scout, Black
SOLD LAST YEAR: 2006 Triumph Rocket III, Black
SOLD LAST YEAR: 1967 Honda 305 Dream, Black
"Going up the country . . . "
texasgrape is offline
post #5 of 5 (permalink) Old 07-30-2018, 07:16 PM Thread Starter
Arzante's Avatar
Yup anwsered my own question... I don't think I've ever felt so dumb. Yes the petcock was left on which removed the vacuum allowing gas to fall from the tank all the way into the pull pan.
Arzante is offline
Starts fine but won't stay running Izzy's08V2KCLT General Vulcan Talk 5 03-17-2015 01:05 PM
My vaquero won't start...it's been running fine specially since I installed the PCV element80 Vulcan 1700 22 03-13-2012 07:38 AM
Gotta Do some engine work and need some advice simonsq Engine Work 5 03-02-2012 03:13 PM
Deal of the Week... just not the right week? Poncho Villa General Vulcan Talk 4 11-11-2011 07:14 AM
idles fine, tries to die when i release the clucth Green Scorpio Vulcan 800 3 09-17-2010 03:38 PM
