Oil Pressure Switch Location - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 05-11-2018, 02:22 PM Thread Starter
Hi I'm wondering if the oil pressure switch is the thing next to the oil filter on the right hand side of this 2004 Drifter vn800? and if so is there a right up on how to install a new one? this one is leaking fluid after I shut off the bike or as its running. thanks in advance.
lostsoulscycles is offline
post #2 of 2 (permalink) Old 05-11-2018, 06:38 PM
Hot Cruiser's Avatar
That's where the oil pressure switch is on my 900 - should be a wire leading from it. Replacing it should be easy - carefully use an end wrench to turn the switch counter-clockwise by the mounting point. Suggest using sealing compound or plumbers' sealing tape on the threads of the new one to prevent leakage.
Jesus is Lord
Hot Cruiser is offline
Ignition Switch to Toggle Switch - Resistor? fieldschadl Vulcan 800 4 04-23-2018 10:04 AM
Neutral indicator switch location tehnis Vulcan 800 3 08-09-2016 12:00 PM
Oil Pressure Switch Connector cp___32 Vulcan 1500 3 04-28-2016 11:35 AM
Ray's Fan Switch Mod - Location Glenn54 Vulcan 1700 6 04-07-2016 05:41 PM
Thinking of Designing an Oil Pressure adapter for oil pressure and temp gauge bikeman2011 Vulcan 900 1 04-20-2011 05:01 PM
