Front brake buzz. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 05-05-2018, 02:46 PM Thread Starter
RedHorse's Avatar
Year/Make/Model: VN 1500 Classic
Displacement/CC's: 1500
Color: Black
Front brake buzz.
Ever since I have owned my '98 Classic, I have had a faint 'buzz' when applying the front brake. It sounds as though it is electrical and at first I thought that it may have been the brake light, however it doesn't happen with the rear brake. It doesn't happen if the brake is applied when the bike is stopped, only when moving. It is not a 'rotary' noise and it is exactly the same regardless of speed or the amount the lever is moved, just applying a little pressure to the lever is enough to cause it. Braking is not effected and the brake pads, caliper and disc are all good and nothing appears to be loose. I do have a stainless braided brake line and I noticed today that there is a very slight kink where it had been pinched about halfway down. Could this be the cause of the buzz? It seems unlikely. As it doesn't effect the braking I'm not too concerned, but just thought I would ask if anybody else has experienced this. I heard of some vn750's that had something similar.
RedHorse is offline
post #2 of 2 (permalink) Old 05-06-2018, 04:22 AM
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Displacement/CC's: 800
Color: black
I think is nothing to worry about. Mine does the same. Could be from the pads, as these are organic, not sinterized. And I know that organic pads are making some noise.
Just my 2c.
marcelm is offline
Backrest Buzz vulcanfitness Vulcan 900 25 05-18-2015 05:10 PM
Won't start...just loud buzz noise! electricd7 Vulcan 900 16 05-27-2014 10:16 AM
04 vn2000 head light buzz solved GUNBUNNY2BG4U Vulcan 2000 0 06-19-2011 10:36 AM
Ground loop buzz raw6464 Vulcan 1700 7 08-15-2010 09:47 PM
buzz butt 1600 nomad hoop57 Vulcan 1600 4 04-14-2010 11:38 AM
