Coolant not draining? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 04-13-2018, 01:51 PM Thread Starter
RedHorse's Avatar
Year/Make/Model: VN 1500 Classic
Displacement/CC's: 1500
Color: Black
I know that there have been similar posts to this as I have just read one from 2012. Unfortunately, there was no satisfactory conclusion as regards the cause. I have changed the coolant on my 1998 Classic today, the first time since I have owned it. I followed the usual instructions, removing the speedometer housing and the radiator filler cap. When I removed the coolant drain plug from the bottom right of the engine case, the coolant did not drain. I checked to see if the drain was blocked, but it wasn't. I was able to insert my small screwdriver through the drain into the engine case at least 4'', but it appeared to be dry. I finally removed the hose from the bottom of the radiator where it connects to the pump. It drained and I collected 1.8 liters of old coolant. The capacity of the system I think is 2.4 liters, which means that I had only drained the coolant from the radiator and not the engine. I replaced the hose and re-filled the radiator with distilled water and ran the bike until hot. I then drained it again and the water was slightly green, so it had passed through the engine and removed the old coolant. Again, the amount drained was 1.8 liters, so 600 ml of water remained in the engine.
I then repeated this, filling the radiator with premixed coolant and ran the bike again until hot. I then drained it again and collected 1.8 liters of what appeared to be just pure green coolant. Obviously, as before 600 ml of coolant had remained in the engine. I finally finished by refilling the radiator with coolant. This was a long drawn out way to ensure that ALL the coolant had been fully replaced, I am still very confused by the fact that at no time did any coolant come out of the drain. The bike has always run very well and doesn't overheat and the cooling fan operates normally at the correct temperature. I just can't figure it out but would like to, as today's coolant change took me 4 hours as I had to wait for the bike to cool before each re-fill. Please any ideas?
RedHorse is offline
post #2 of 7 (permalink) Old 04-13-2018, 02:00 PM
VN750Guy**'s Avatar
Year/Make/Model: 2006
Displacement/CC's: 750
Color: Red/black
Does the 800 engine have spots on the cylinders where you can remove a plug and drain the coolant passage from the cylinder? It may not have them for all that I know.
I mention this because my 750 has a plug on each cylinder that is located in the lowest spot of coolant passages in the cylinder. The passage there is like the letter "L" but tilted 45 degrees on the side counterclockwise. That particular place will never drain completely unless the drain lug is removed.
I don't know if your engine has corresponding drain plugs.
Chris Cochran
Retired USAF '74 to '95 AMMO
Engine guard with highway pegs
Luggage rack
GPS on RAM handlebar mount
MCCTs replaced ACCTs
Iridium plugs: DPR7EIX-9
Custom made seat (verrry comfortable)
LED turn signals with rear signals relocated
LED license plate holder
Hard mounted Viking saddlebags
Hard mounted fork tool bag (free from Viking)
LED running lights on custom light bar
National Cycles Low Boy Heavy Duty windshield
Home made lowers
VN750Guy** is offline
post #3 of 7 (permalink) Old 04-13-2018, 02:08 PM
VN750Guy**'s Avatar
Color: Red/black
Incidentally, why the name Red Horse?
Chris Cochran
Luggage rack
Home made lowers
post #4 of 7 (permalink) Old 04-13-2018, 03:31 PM Thread Starter
RedHorse's Avatar
Color: Black
I have lived many years in the Philippines. 'Red Horse' is a strong beer, made by San Miguel that I drink. (a lot)
The vn800 doesn't have a drain on each cylinder.....that's only the 750
RedHorse is offline
post #5 of 7 (permalink) Old 04-13-2018, 03:53 PM
VN750Guy**'s Avatar
Color: Red/black
I was wondering about the Red Horse thing because in the USAF, Red Horse, was the common name given to Civil Engineer type folks. There was a great rivalry between Red Horse troops and the AMMO troops (bomb dump guys). I was an AMMO troop.
At least, this was the way it was when I was active duty, but I've been retired out of the USAF for 23 years now.
As for the 800 draining issue goes, I can't help ya there.
Chris Cochran
Luggage rack
Home made lowers
post #6 of 7 (permalink) Old 04-15-2018, 11:22 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
dam it, after seeing the picture of that red horse beer bottle i want to have about 8 of 'em then ride thru town, lol
btom is offline
post #7 of 7 (permalink) Old 04-22-2018, 06:43 PM
texasgrape's Avatar
Year/Make/Model: 1996 Kawasaki Vulcan 800 Classic
Color: Blue-Green
NO coolant will drain out of my 800 unless the radiator top is open. Once open, it gushes out. It acts like a finger on top of a straw that is full of liquid.
1996 Vulcan 800, Blue/Green
JUST SOLD: 2016 Indian Scout, Black
SOLD LAST YEAR: 2006 Triumph Rocket III, Black
SOLD LAST YEAR: 1967 Honda 305 Dream, Black
"Going up the country . . . "
texasgrape is offline
Coolant not draining? RedHorse General Vulcan Talk 0 04-13-2018 01:40 PM
draining the carbs ifiddles Vulcan 500 12 11-11-2011 09:36 AM
GPS power cord draining battery.... X-Rider Vulcan 900 25 05-14-2011 08:31 AM
gasoline draining into transparent reservoir Fredsvulcan Vulcan 500 2 05-03-2010 06:30 AM
