clutch needs adjustment ?? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 02-20-2018, 05:53 PM Thread Starter
Year/Make/Model: 2001 vulcan 800 classic
Displacement/CC's: 800
Color: two tone blue / grey
vulcan 800 classic had a new air cleaner installed and rear tire installed and did a couple of test runs down the driveway but now when its into 1st gear and the clutch is released it is almost like its in 2nd gear, and i have to rev up the gas and release the clutch very slowly to get it to let it engage. any idea what to check out first?
one thing i had new clutch and brake levers put on by the same shop that did the rear tire install, but they said it was fine when it left there shop...
thanks
Bill22 is offline
post #2 of 9 (permalink) Old 02-20-2018, 10:07 PM
1. When you try to get rolling, does the engine cough, sputter or?
2. Once underway, is everything normal?
sfair is offline
post #3 of 9 (permalink) Old 02-20-2018, 11:01 PM Thread Starter
Once I get it moving I go on up into 2nd gear and it seems to be ok, it seems to be a little louder that usual more of a POP comminng from the exhaust, it's been in the shop for almost a month so maybe I'm looking for priblems?
Bill22 is offline
post #4 of 9 (permalink) Old 02-20-2018, 11:05 PM Thread Starter
One other thing, if I turn the handlebars straight and use the adjustment nut and wheel on the clutch handle and lever mount to make the lever get into that tension spot that feel right, then if I turn the handle bars to the left the cable seems to get tight or stretched and the lever tension becomes very tight...
Bill22 is offline
post #5 of 9 (permalink) Old 02-21-2018, 10:02 AM
So you are saying that it seems like it is in second gear to start off, but it really is not?
Also, on the handlebar issue, it could be that the clutch cable is routed incorrectly and catching on something that is making it stretch.
sfair is offline
post #6 of 9 (permalink) Old 02-21-2018, 11:42 AM Thread Starter
Yea kinda, I put it into 1st and then let off the clutch, it does engage, but it feels like I have to give it more and more gas to take off and into 2nd. The clutch cable has never been replaced only the lever was replaced, so is there a way to set the adjustment back to stock or something?
Bill22 is offline
post #7 of 9 (permalink) Old 02-21-2018, 11:49 AM Thread Starter
The thing with the cable being tight when the bars are turned to the left, even if I get the clutch lever adjusted in the middle if i turn them to the left the lever goes very tight then back to loose when there straighten up, that has never happened before so I know the cable is out of adjustment someplace
Bill22 is offline
post #8 of 9 (permalink) Old 02-21-2018, 01:08 PM
With handlebars centered, is the cable itself loosie goosie?
sfair is offline
post #9 of 9 (permalink) Old 02-21-2018, 06:36 PM Thread Starter
Update: I think I found out what it might be, one of the things we done to the bike other than air filter, was new mirrors and new clutch and brake levers, and i think when the clutch lever mounting pice was loosened to get the new lever on it was pushed to close to the grip and that was what pulled all the slack out of the clutch cable. I loosened it up moved it over about 2 or inches and it loosened up.i also put new spark plugs in and I did a test run and it seem to be ok. Grabbed my helmet and went around the block a few times and it seemed ok. I still have to fix the air filter problem but I will take 1 problem orver 3 anytime.
Thanks for everyone's help
Bill22 is offline
Clutch needs replacement? 12slvrlancer Vulcan 1500 5 06-17-2016 11:46 AM
Is there any clutch adjustment on mean streak hyd clutch ? DARKSIDER Vulcan 1600 8 12-01-2011 07:34 AM
My baby needs a clutch spring catch640 Vulcan 1500 7 03-21-2011 06:27 AM
Clutch Adjustment Pretzel Vulcan 900 5 07-13-2009 11:55 AM
Clutch Adjustment jiman Vulcan 500 1 10-19-2008 10:40 PM
