My 1st Cycle, 47k miles - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 01-31-2018, 01:51 PM Thread Starter
Lal
Lal's Avatar
Question My 1st Cycle, 47k miles
Thank you posters for having been helpful to so many confused riders. I am one of them. Been two weeks since i got my 800, and here are some of the issues i would be happy to resolve with your help.
! : I have barely any specific tools, just the basics.
Inspection: Requirements left : Horn, turn signal.
Horn problem: The given horn would not work, even after bolting it on & trying it after starting the engine.I have tried to buy a new horn, and it would not make even a chirp. What could i do to remedy this?
Turn signal problem: The night that i went to check it out for the first time, the motorcycle started and the turn signals worked fine.
However, now in my possession, the turn signals ONLY WORK LIKE NORMAL when i am moving. ie: If i am stopped or slow, it will inconsistently blink and get dimmer. BUT! it will work again at a stop/slow IF i rev and ONLY if the cycle is revved. What could be causing this delima?
Now the MOST important thing i'm facing: My engine won't start. I rode it two days ago. When i tried to start it today, i pulled the choke to give it a little gas, and i could hear the gas flowing in. And then it got quieter and quieter. I thought it was good on idle so i tried to let go of the clutch, it just died. So i have an inclining that it has something to do with the choke, as it did give a notable auditory change after i pulled it for a couple of seconds. The change being: loud like it's revving, to a idle.
I appreciate and time and effort you guys would lend me. Thank you!
Lal is offline
post #2 of 2 (permalink) Old 02-02-2018, 08:44 AM
Year/Make/Model: 2011 Vulcan Voyager
Color: Blue/Silver
I don't know if the 800 has a horn relay or not, but given the horn and turn signal issue, first thing I'd do is check the battery's voltage. I'd also look at the connections at both the horn and turn signal switch.
What do you mean by not starting? What got quieter and quieter? Does it crank, just run over slowly, start but die when you let out the clutch?
Bluemeanie is offline
Hard to Shift to 1st and Disengages at 1st tedkawi Vulcan 900 15 08-22-2013 01:25 AM
Nomad 01-15K miles 1st $3995 takes TODAY louichie Bikes For Sale 1 12-02-2011 05:04 PM
My 1st 2000 miles cruiser331 Vulcan 900 1 07-10-2009 05:54 PM
My 1st 1000 miles cruiser331 Vulcan 900 13 06-20-2009 04:58 PM
Cycle Nation cycle parts kjaxntn Vulcan 900 1 03-01-2009 02:43 PM
