Choke on increases idle when warm. Normal? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 01-21-2018, 07:06 PM Thread Starter
texasgrape's Avatar
Year/Make/Model: 1996 Kawasaki Vulcan 800 Classic
Displacement/CC's: 800
Color: Blue-Green
Most bikes I have had, once the bike is warm and you pull out the choke knob (enriching), the bike sputters/floods and dies. I just replaced this bike with a new choke mechanism (plunger and cable). Now when the bike is warm and I pull out the choke knob, the bike increases in rpm and doesn't cough or sputter--just increases in rpm. Otherwise bike runs good, no popping, no backfiring, no bogging.
I'm fixing to pull the carb again (pesky bowl gasket leaking) so is there any thing I need to do while the carb is off? Or can the lack of sputtering/dying be normal? Any thoughts/guidance?
Stock jetting, stock air intake, Cobra pipes w/baffles in, 2000' altitude. Thanks.
1996 Vulcan 800, Blue/Green
JUST SOLD: 2016 Indian Scout, Black
SOLD LAST YEAR: 2006 Triumph Rocket III, Black
SOLD LAST YEAR: 1967 Honda 305 Dream, Black
"Going up the country . . . "
texasgrape is offline
post #2 of 4 (permalink) Old 01-22-2018, 01:24 AM
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Color: black
Out of my knowdlege, this could indicate a lean condition.
marcelm is online now
post #3 of 4 (permalink) Old 01-22-2018, 07:04 AM
Color: Black / grey
On a non-enriching normal choke setup if you pull the choke the rpms should increase.
Had it happen many times before.
vulcandoc is online now
post #4 of 4 (permalink) Old 02-20-2018, 03:26 PM Thread Starter
texasgrape's Avatar
Color: Blue-Green
Just an update: Installed next larger size pilot jet (50) and that corrected the problem. Now when I pull the choke out a little, rpms increase like Vulcandoc said, but pull it out all the way, it sputters badly, which is what I was used to. I was also able to better dial in my fuel mixture screw. It was at 4 1/2 turns out, now back to 2 1/2. For all those who say rejecting is not necessary with just aftermarket pipes, this bike with these particular Cobra tapered pipes (with baffles) did require a pilot jet change when the fuel screw alone would not remedy the lean condition.
Now I'm fixing to Grampsize so it all gets tuned differently now. LOL
Idle increases when shift from 1st to neutral iamtheanimal Vulcan 900 3 03-31-2018 03:48 PM
Idle idle idle Derek Vulcan 800 9 04-23-2017 08:49 AM
To warm up or not warm up? keller123 General Vulcan Talk 25 09-27-2013 11:48 AM
Premium gas increases "Kawi-tick" silenthill Vulcan 900 20 08-30-2010 10:16 AM
