What did I miss? Troubleshooting. IC Igniter? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 20 (permalink) Old 01-13-2018, 11:46 AM Thread Starter
texasgrape's Avatar
Year/Make/Model: 1996 Kawasaki Vulcan 800 Classic
Displacement/CC's: 800
Color: Blue-Green
Just bought 1996 Classic 800 w/18K miles—my second one to own. NOTE: I did a title check and it has changed hands many times and in short periods of time indicating no PO’s could fix the bike. I don’t want to be a title statistic. LOL I think I found the problem.
Symptoms: Bike starts right up with choke on and idles only on choke. Take if off choke it dies, or if you throttle it with choke off, it barely runs with seemingly no power. Drove it around block. No power. Will not idle with choke off. Compression 165 and 175 (cold). All valve clearances set perfectly by me, first thing I checked. All were out of spec and 2 intakes were at zero.
1. Classic pilot jet plugged symptom, right? Disassembled and cleaned carb, it was pristine.
2. Drained gas, milky in color. Orange tint. Changed gas. No improvement (NI).
3. There was a little fuel filter with inline 1/4 turn valve. Restriction? Took it all off and put on factory fuel line. NI.
4. Petcock leaks on both RES and ON. Replaced w/OEM petcock. NI. Replaced vacuum line from petcock to carb. NI.
5. Pulled coils, both tested good per Kawa manual.
6. Trimmed coil leads and plug leads and reinserted. NI.
7. Finally I checked for sparks using both the plugs and spark tester. I found a weak orange spark on front. NO SPARK on rear! (SEE POST #19)
8. Swapped wires. NI.
9. Swapped coils, same as if I’d not swapped them. Weak orange spark on front, no spark on rear.
10. Tested pick up coil per Kawa manual. Tested good.
11. Continuity good from IC Igniter to rear coil.
So I tested the IC Igniter per Kawa manual. I have a Fluke digital but did not use it per reading Kawa manual and forums. So I bought an analog and used it to perform test. (I know about what the Kawa manual states about only using theirs, but I have read it’s not so much their brand as it is using an analog. Besides, if you have resistance where you are supposed to have infinity, the exact reading doesn’t matter.)
I did a meticulous test and wrote down all measurements. 68 total checks. Pin 5 showed continuity (resistance) on 5 of the 7 tests where it should have been infinity. There were 3 other readings on Pin 5 way out of range.
This brings me to the reason for this post: Before I spend big bucks on an IC Igniter, did I miss anything? Any other checks I need to do? I’m convinced the IC Igniter is bad because of Pin 5 resistances, but how many times have we been “convinced” only to find we missed something. All input appreciated.
texasgrape is offline
post #2 of 20 (permalink) Old 01-13-2018, 04:28 PM
Post a picture of the plugs.
sfair is offline
post #3 of 20 (permalink) Old 01-13-2018, 05:41 PM Thread Starter
texasgrape's Avatar
Color: Blue-Green
New plugs. Other than some idling and a slow/sluggish ride around the block, not much mileage on them. Clean plug from rear.
post #4 of 20 (permalink) Old 01-13-2018, 06:45 PM Thread Starter
texasgrape's Avatar
Color: Blue-Green
More info: Bike had a new OEM coil on rear as well as a new aftermarket plug wire. This would indicate the POs knew of the no spark issue. Another fact: IC igniter bolts were loose indicating it had been removed and put back maybe. Here is the back of the igniter which does not look normal, looks like the filler is rotten or a PO tried digging it out.
Name:	IC Igniter.JPG
ID:	208713   Click image for larger version
Name:	IC Igniter2.JPG
post #5 of 20 (permalink) Old 01-14-2018, 12:37 AM
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Color: black
Air box, exhausts & carb (jets) are stock ?
marcelm is offline
post #6 of 20 (permalink) Old 01-14-2018, 08:08 AM Thread Starter
texasgrape's Avatar
Color: Blue-Green
Air box and jets are stock. Exhaust is Cobra (w/baffles inside).
post #7 of 20 (permalink) Old 01-14-2018, 10:29 AM
Post the make and model # of your analog meter for my reference.
sfair is offline
post #8 of 20 (permalink) Old 01-14-2018, 11:16 AM Thread Starter
texasgrape's Avatar
Color: Blue-Green
I figured you would ask, and I almost posted it originally. LOL Commercial Electric M1015B 300v CAT II. (From Home Depot)
post #9 of 20 (permalink) Old 01-15-2018, 10:56 AM
To make the most sense of the test I would like you to do, it is best to have a meter with an X1 ohms scale such as this one:
Sunwa YX360-TRD 7-Function 16-Range Analog Multimeter With One Touch Capacitance Estimation | Multimeterwarehouse
sfair is offline
post #10 of 20 (permalink) Old 01-15-2018, 06:39 PM Thread Starter
texasgrape's Avatar
Color: Blue-Green
Mine has 1X and 10X ohms. Here is the one I have: https://www.homedepot.com/p/Commerci...gue+multimeter
I have no problem buying another if that is what I need to do, but will the one I have work? (I also have a fancy Fluke digital.)
IC ignitor box removal Pagman Vulcan 800 2 06-04-2015 06:23 PM
Did I miss something? Froggy General Vulcan Talk 4 03-26-2013 11:53 AM
Help - Brake Job @#$ up -> what did I miss? lord500 General Vulcan Talk 9 08-15-2011 03:30 PM
Plug cap specs & miss troubleshooting jrupp82 Vulcan 1500 1 04-17-2011 09:34 PM
IC Ignitor question xbhowellx Vulcan 800 4 07-18-2010 05:11 PM
