air/fuel mixture,help - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #1 of 12 (permalink) Old 01-10-2018, 02:21 PM Thread Starter
cevherrr's Avatar
Year/Make/Model: 1996/Kawasaki/Vulcan 800
Hello everyone, I cleaned the carburettor today, I changed the setting of the pilot screw, the original air filter and the exhaust. How many turns should I turn the mixture screw?(factory reset) I apologize for my poor english :/
cevherrr is offline
post #2 of 12 (permalink) Old 01-11-2018, 08:40 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
1.5 turns on pilot mixture screw
cevherrr likes this.
btom is offline
post #3 of 12 (permalink) Old 01-11-2018, 11:29 AM Thread Starter
cevherrr's Avatar
I thought it was 2.5 turns, thank you
cevherrr is offline
post #4 of 12 (permalink) Old 01-11-2018, 02:05 PM
If you can.....tweak pilot screw as required to deliver its highest rpm and best throttle response, engine idling, fully warmed (actually ridden)
custom carb service is offline
post #5 of 12 (permalink) Old 01-11-2018, 02:19 PM Thread Starter
cevherrr's Avatar
I can not adjust the screw without removing the carburetor :ciddi: a picture help me or tool? I can : Grin2: Thanks
cevherrr is offline
post #6 of 12 (permalink) Old 01-12-2018, 07:02 AM
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Color: black
Yes, you can. It's not very easy, but it's working, just need an articulated screwdriver. This is how I adjust mine.
The picture is just for reference.
marcelm is offline
post #7 of 12 (permalink) Old 01-12-2018, 08:29 AM
texasgrape's Avatar
Year/Make/Model: 1996 Kawasaki Vulcan 800 Classic
Color: Blue-Green
Walmart has a screwdriver on a spring which bends and comes with different sized flatheads/Phillips. I bought one last week and it fits perfectly. NAPA has one too, but you will need to get your own hex-flathead inserts yourself. Also, you DO NOT need to remove carb to adjust screw. Worst case, just remove the air filter housing bolts (2) and disconnect hoses at the bottom of housing on back side. Then push it towards the handlebars to get it out of the way. Screw is indeed hard to get to. Before I got my spring screwdriver, I would make a small adjustment with a short thin screwdriver, then put air filter back on, test. Repeated as necessary. FYI, my Kawa manual states 1 3/4 turns out, but that is only a starting point. Good luck.
texasgrape is offline
post #8 of 12 (permalink) Old 01-12-2018, 01:45 PM Thread Starter
cevherrr's Avatar
My dear friends thank you very much for answers, would the setting made by removing the air filter box and its pipes be correct? I guess this is my only chance
cevherrr is offline
post #9 of 12 (permalink) Old 01-12-2018, 02:42 PM
texasgrape's Avatar
Color: Blue-Green
Yes, perfect. Now just find a small screwdriver that fits the fuel screw. It will be difficult to hold onto and twist if you have large hands, but I just take my time. With a flexible screwdriver it's very easy. You can find them on eBay, Amazon, Walmart, etc.
post #10 of 12 (permalink) Old 01-13-2018, 07:06 AM
btom's Avatar
i have a flexible screwdriver but those are too big to fit up there and you cannot see the turns, use a very tiny screwdriver in your one hand and do it that way, it's hard but can be done with lots of patience
btom is offline
air/fuel mixture adjust vulcan 900 andrei00y Vulcan 900 0 08-02-2012 10:41 AM
Air/Fuel Mixture Screw helljack6 Vulcan 800 0 05-23-2012 11:09 PM
Air/fuel mixture test... by sound? Zim_the_Giant General Vulcan Talk 12 04-10-2012 01:15 PM
Air/Fuel mixture adjustment help. Vulcan 800 rear cyl running rich. Pa. Vulcan Engine Work 12 06-20-2011 04:05 PM
Air Fuel Mixture Screw Tester Needed by Baron Custom Accessories John Baron Vulcan 1500 0 11-16-2009 05:03 PM
