Air Chamber Question - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By trainermb
post #1 of 8 (permalink) Old 12-26-2017, 06:06 PM Thread Starter
texasgrape's Avatar
Year/Make/Model: 1996 Kawasaki Vulcan 800 Classic
Displacement/CC's: 800
Color: Blue-Green
What change in performance would be experienced by running without the air chamber (air box) vs running with it? PO forgot to include it when I purchased the Classic 800. Although bike starts right up and idles, it seems very sluggish. Would running without the air chamber have anything to do with that? (PO is mailing the air chamber to me.) Thanks.
texasgrape is offline
post #2 of 8 (permalink) Old 12-27-2017, 09:23 AM
btom's Avatar
Year/Make/Model: '05
stock backing plate, stock paper filter and chrome cover?
btom is offline
post #3 of 8 (permalink) Old 12-27-2017, 11:09 AM
trainermb's Avatar
Year/Make/Model: 2007 Kawasaki Vulcan 900 Classic LT
Displacement/CC's: 900
Color: Black & Silver
Air boxes are designed to be resonant chambers.
Resonance is a state of minimum resistance to flow -- whether we're talking about air, water, sound waves, or even electricity. So by serving as a resonant chamber, the air box drastically reduces the resistance to air flow into the engine. Indeed, if everything's timed out right, it acts something like a (small ...) (very small ....) turbocharger, actually raising the air pressure at the intake at the moment the intake opens.
All that adds up to, yes, that missing air box could at least be contributing to sluggish performance.
texasgrape likes this.
"Don't force it. Get a bigger hammer."
- William Shakespeare
trainermb is offline
post #4 of 8 (permalink) Old 12-27-2017, 06:30 PM Thread Starter
texasgrape's Avatar
Color: Blue-Green
Yes to all the above. Bike is stock, just no air chamber.
post #5 of 8 (permalink) Old 12-28-2017, 08:55 PM
Beans's Avatar
Year/Make/Model: 2005 Vulcan 800 Classic
I would give the carb a look over before you install the air chamber under the tank. The jets could have been changed, or the carb could need a good clean. Removing the tank and air chamber is like half way to having the carb off, so might as well do it now.
Never argue with a fool: onlookers may not be able to tell the difference.
Beans is offline
post #6 of 8 (permalink) Old 12-29-2017, 08:47 AM
btom's Avatar
after-market air boxes for the 800 are hard to find, and thunder mfg in AZ who sold 800 air boxes went out of business
btom is offline
post #7 of 8 (permalink) Old 12-29-2017, 12:30 PM Thread Starter
texasgrape's Avatar
Color: Blue-Green
I pulled the carb when I adjusted the valves. Carb has correct jetting and is in great shape--gave a thorough cleaning. I rec'd the OEM airbox from PO today, will install it once I am feeling better. Have to change the oil too. (WAY WAY above sight glass. Hope it's all oil.)
post #8 of 8 (permalink) Old 12-31-2017, 12:17 PM
btom's Avatar
when it comes to oil in the crankcase and you just got a used bike from previous owner, change out the oil because never assume what another person has done to your bike and when it was done, change it out anyways so that you will have your own record of what was done and when it was done
btom is offline
Gasoline in air chamber BgDddySUM Vulcan 500 5 04-19-2012 09:30 PM
1994 Vulcan 1500A Float Chamber needed bri4406 Bikes For Sale 0 09-13-2009 08:59 AM
gas in the air cut off chamber? pugetsoundsailer Vulcan 1500 0 05-31-2009 04:24 PM
