gps power cable hookup - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 12-13-2017, 03:24 PM Thread Starter
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
3 places to connect my garmin zumo 550 gps power cable, 1- inside headlight bucket accessory leads, 2- rear accessory leads (but not sure where those are at), 3- battery terminals. Where should I do the hookup at?
btom is online now
post #2 of 5 (permalink) Old 12-14-2017, 01:09 PM Thread Starter
btom's Avatar
I installed the cradle and power cable, used the (+) (-) always hot accessory leads inside the headlight bucket, now going to put music on a SD card and plug that into the Zumo
btom is online now
post #3 of 5 (permalink) Old 12-19-2017, 11:16 PM
Sabre-t's Avatar
Color: Red/Black
Personally, I never power accessories from an always on source unless I install a manual switch in line or a relay to a keyed source. If that GPS goes into a sleep mode when power is removed and you can find a mount that can even remotely be considered "secure" you might be happier with a power source that turns on with the key. From the battery or the headlight bucket (if there is room), that can be accomplished with a relay.
I have a TomTom Rider 400 with their "secure" RAM mount. A determined thief could defeat it, but you won't casually remove the GPS when it is locked in. I like that the GPS goes to sleep when I turn off the power at the key. Chances are that I will never kill my bike battery because I forgot to turn off an accessory, but those chances rise to near certainty the further I am from home or civilization. Just like the stator on my Sabre burned out, not once, but twice when I was in the middle of nowhere! Murphy was a real jerk.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #4 of 5 (permalink) Old 12-20-2017, 07:35 AM Thread Starter
btom's Avatar
the power to cradle always-on is kind of handy when turning off the motor to gas up and then starting up again and the gps still has a sat signal and map running
btom is online now
post #5 of 5 (permalink) Old 12-20-2017, 10:10 PM
Sabre-t's Avatar
Color: Red/Black
I've never used a Garmin GPS, but my TomTom Rider goes to sleep when the power is cut and starts back up, almost instantly, when power is restored. Within a few seconds, all Bluetooth and sat signals are fully operational. If I shut it down completely, well, that's another story, but it can stay in sleep mode for at least a couple of days without depleting the battery, which is usually fully charged from riding.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
Kawasaki GPS Connection Cable with Other GPS Units Kap Vulcan 1700 5 11-06-2015 10:18 AM
2006 nomad 1600 wont run unless the charger is hookup terryhan05 New Member Introductions 4 02-25-2014 11:33 AM
Lightbar hookup AL500 Vulcan 500 21 12-14-2011 01:51 PM
1700 Voyager (GPS Power) t-bear Vulcan 1700 16 03-18-2011 09:18 AM
12 volt accessory hookup question with a pic blakeh Vulcan 900 4 09-25-2010 12:03 AM
