Single bolt handlebar riser question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 12-03-2017, 10:55 PM Thread Starter
Soulless303's Avatar
Year/Make/Model: 1996 Kawasaki Vulcan 800
Color: Red
I have a 96 and I want to change out the handlebars to a dragbar. Looking at the bcb kits they recommend risers to avoid the switches from hitting the tank. I see they have risers for the 2 bolt style but can't find any for the single bolt. Maybe my searching skills suck lol. Can I switch out to the 2 bolt style? I found biltwell gordo risers but the mounting bolt is larger than what the opening is. Am I safe to open the holes to a larger size? Or are there any other riders that have a drag bar that can offer their insight? Thanks!
Soulless303 is offline
post #2 of 6 (permalink) Old 12-04-2017, 11:26 AM
rick's Avatar
Not sure what you mean by 1 or 2 bolt risers. Do you mean how the caps attach to the risers, or how the risers mount to the tree? As for drilling the tree to accept a larger bolt, I had to do this on my 05 800 when I bought taller risers, as most after market riser are made with 1/2" bolts to mount them, but the stock bolts on mine are 12mm I believe, slightly smaller.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 6 (permalink) Old 12-04-2017, 11:51 AM Thread Starter
Color: Red
Yeah, sorry, how the cap bolts to the riser. Is it possible to swap to the 2 bolt style cap? I would like to avoid drilling the tree if possible but will go that route if needed. Thanks!
post #4 of 6 (permalink) Old 12-04-2017, 11:46 PM
Beans's Avatar
Year/Make/Model: 2005 Vulcan 800 Classic
I installed some Biltwell handlebars and risers on my bike. I drilled out the top tree stepping up one drill bit at a time to make sure the holes weren't all cock-eyed. I was a bit nervous since it couldn't be undone, but it turned out just fine. Keep the drill straight and go slowly if you decide to drill it out.
Never argue with a fool: onlookers may not be able to tell the difference.
Beans is offline
post #5 of 6 (permalink) Old 12-05-2017, 07:21 PM Thread Starter
Color: Red
Yeah, I'm going to order the newer style with the 2 bolt cap to see if I can't just swap them out. If that does not work then I'll get the biltwell risers and drill the holes a bit bigger. Which model of the risers and handlebars did you go with?
post #6 of 6 (permalink) Old 12-19-2017, 09:44 PM
Beans's Avatar
I went with Biltwell Chumps bars and Thunder risers. I was just looking at a post where I posted some pictures, but I can't seem to find it now... It looks siiiiiick!
Beans is offline
Riser mounting bolt diameter for 900 classic Rohan874 Vulcan 900 3 07-18-2018 07:31 AM
Handlebar Riser Question colemantle Vulcan 900 4 06-13-2016 12:15 PM
Correct bolt size for steering head fork clamp bolt aeroden Vulcan 1500 3 12-29-2014 03:34 AM
Handlebar/Riser/Grips question drgck Vulcan 900 3 05-22-2013 10:30 PM
3 general question! Handlebar/Riser/Shocks Evil Scotsman General Vulcan Talk 8 07-17-2010 01:21 PM
