Trip Meter - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 11-21-2017, 01:51 AM Thread Starter
RedHorse's Avatar
Year/Make/Model: VN 1500 Classic
Displacement/CC's: 1500
Color: Black
Trip Meter
I recently bought my 1998 Vulcan 800 Classic from a friend who had owned it since 2002. The speedometer and odometer work fine, and it has 17,000 miles. However, the trip meter is not working correctly. I usually rely on a trip meter for re-fueling, in the absence of a fuel gauge.
The trip meter will roll forward, however all the digits roll forward at the same time at different speeds. If I reset it to 0000, a short run around the block for instance, will return a reading of 634 miles??? all the digits are spinning!
I don't want to replace the entire speedometer gauge, but I'm not sure what is causing this, or if it can be repaired.
Any advice is appreciated.
RedHorse is offline
post #2 of 5 (permalink) Old 11-21-2017, 08:30 AM
rick's Avatar
I dont think there is much that can be done with it short of replacing. Its kind of a sealed unit.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 5 (permalink) Old 11-21-2017, 01:41 PM
Ante87's Avatar
Year/Make/Model: 98 Kawasaki VN800
Displacement/CC's: 800
Color: Black/Red
Sort of have the same problem.
My trip counter goes up to 29 kilometers then it doesn't turn over to 30 but starts over at 20 again.
Planning to try to disassemble it this winter.
I'll return with the results if I manage to open it
Skickat från min PLK-L01 via Tapatalk
Ante87 is offline
post #4 of 5 (permalink) Old 11-25-2017, 04:54 PM
Ante87's Avatar
Color: Black/Red
Manage to open the speedo.
Had to gently bend the edge of the steel ring at the back of the speedo.
Took of the needle and the background (or wathever it's called). However I didn't manage to get the gearhousing out because of the trip resetknob.
It's a brass extension thats threaded to the reset axle and it's stuck there pretty good...
So I gave up. I don't think its worth it and if my problem doesn't sort itself out (witch is unlikely) I'm buying a new or second hand speedo.
Anyway here's some pictures if you diced to try for yourself.
A word of warning though. The speedo gonna show signs of being opend. Maybe it doesn't matter on a bike that age but you never know what people gonna think...
Good luck
Ante87 is offline
post #5 of 5 (permalink) Old 11-28-2017, 03:31 AM Thread Starter
RedHorse's Avatar
Color: Black
Yeah, seems like more trouble than it's worth. Think I'll just leave it as it is, or buy a used replacement gauge. Thanks anyway!
RedHorse is offline
trip meter/clock resetting MICKEY2 Vulcan 1700 1 06-13-2015 07:20 PM
Trip meter reset AZGeek Vulcan 900 10 04-15-2015 03:32 PM
clock, trip meter, battery..... Midd-Cruzer Vulcan 1600 8 07-22-2012 07:23 AM
Speedometer and trip meter/miles gauge HeUeR Vulcan 900 3 06-03-2010 10:14 PM
2004 Vulcan 800, How do i reset my trip meter? accordpower99 General Vulcan Talk 6 09-04-2009 08:52 PM
