Swingarm Bearing Replacement - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 11-03-2017, 08:59 AM Thread Starter
WaterFoul's Avatar
Year/Make/Model: 2003 Kawasaki Vulcan VN 800B Classic
Displacement/CC's: 800
Color: Red
Any advice on how to press in new bearings on our bikes? The swingarm has one continuous tube which makes it harder to find a bearing press that will work.
ex of what I'm referring to:
This one is separated in the middle, making it easy to just use a vice and socket to press them in.
The VN800 doesn't work with that method...
Or, using a "fancy" tool - bolt would need to be much longer: https://youtu.be/kxVVa69Rw78?t=455
WaterFoul is offline
post #2 of 2 (permalink) Old 11-04-2017, 02:26 AM
Beans's Avatar
Year/Make/Model: 2005 Vulcan 800 Classic
You could try some Ready Rod (threaded rod available at Home Depot, etc.) and a two nuts and some washers and see how that goes. It would be similar to the second video you linked.
Never argue with a fool: onlookers may not be able to tell the difference.
Beans is offline
Steering head bearing replacement JArthur Vulcan 1700 12 03-31-2015 11:55 AM
Steering Stem Bearing replacement procedure questions va3ux Vulcan 1500 6 02-20-2014 01:09 PM
Swingarm bearing caps? or seals? Hound Dog Vulcan 1500 2 02-08-2014 07:30 PM
Swingarm Bearing Lubrication old Vulcan 500 10 05-12-2013 02:06 PM
threaded holes on swingarm? Hollywood98 Vulcan 800 2 10-27-2009 06:17 PM
