Please tell me there's a fix for this... - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #1 of 24 (permalink) Old 09-24-2017, 08:14 PM Thread Starter
Year/Make/Model: 99 Kawasaki Vulcan 800 Classic
Displacement/CC's: 800
Color: Black/Grey
I was taking the float out of the carb to check the float needle, and when I was taking the pin out, one of the pin holders broke off. I do not have another 300-500 for another carb, when I've already put a bunch of money into fixing this bike already. Is there a way to fix this? I've got a few thoughts running through my head, such as super glue, soldering it back on, seeing if it'll stay put with just one pin holder... Any suggestions? I'd really love to finally ride this thing someday. Thanks!
Johnny6String is offline
post #2 of 24 (permalink) Old 09-24-2017, 09:57 PM
Bike Of The Fall Winner 2017
GFISH's Avatar
Year/Make/Model: 2006 Vulcan 900 Classic
Displacement/CC's: 903
Color: Silver
If soldering does not work. I have used JB Weld on a lot of small and large parts with good results.
"As long as I have the voices in my head, I'll never ride alone."
2006 Vulcan 900 classic
Mustang Day Tripper seat
Cobra Light Bar
Cobra Air Scoop
Cobra short sissy bar
Cobra Lowers
Baron's front and rear pulley
Baron's Big and Nasty pipes
Leatherlyke hard bags
Blue Superbrites LED accent lights
Chrome Woo Loo Air Horn
Avon Grips
GFISH is offline
post #3 of 24 (permalink) Old 09-24-2017, 10:56 PM
FTW2017's Avatar
Year/Make/Model: 2000 Vulcan classic
Displacement/CC's: 90 CI 1470 CC
Color: Currently Victory Red
KAWASAKI OEM CARB FLOAT SET 95-05 VULCAN 800 16031-1089 | eBay
AVIATION RULE #1 STAY AWAY FROM THE SHINY SPINNING THINGS
FTW2017 is offline
post #4 of 24 (permalink) Old 09-25-2017, 12:05 AM
Sabre-t's Avatar
Color: Red/Black
He broke the mount, not the float.
JB Weld is supposed to hold up to gasoline. Just make sure it is fully cured before you expose it to gas.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #5 of 24 (permalink) Old 09-25-2017, 05:59 AM
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Color: black
Show it to a professional welder guy. He should know exactly if it can be sold or not.
marcelm is offline
post #6 of 24 (permalink) Old 09-25-2017, 07:02 AM
Color: Black / grey
Soldering is NOT for strength, it for electrical things.
JB weld, or similar is your best bet.
vulcandoc is offline
post #7 of 24 (permalink) Old 09-25-2017, 07:38 AM
marcelm's Avatar
Color: black
I have a different opinion, soldering is also for strength. Definitely you will not have the same strength as the material from which is made the carb, but you can have more that enough strength to hold the float.
The key is to ask the right person.
marcelm is offline
post #8 of 24 (permalink) Old 09-25-2017, 08:28 AM
You CAN NOT solder the aluminum! Even welding is hard. Even it could be welded, first somebody should determine what is the exact aluminum (alloy) type. Different alloy types require different welding techniques.
If You ask me, what would I do, my option would be to drill a little hole (from the top) in that broken leg which is left and make a thread in it. I would screw a screw in it and drill a hole in that screw (according that pin size). Or simply I would use a screw like this.
tehnis is offline
post #9 of 24 (permalink) Old 09-25-2017, 08:39 AM
marcelm's Avatar
Color: black
Yes, is difficult, but :
What I would do : as I said, I would ask a specialist.
I have welded two broken clutch levers so far with no issue. And the clutch lever is not at all easy to weld. Of course, the strength of welded area is less, but enough to pull the clutch.
One of this two levers is from my wife's VN800 and this were years ago, no issue so far.
marcelm is offline
post #10 of 24 (permalink) Old 09-25-2017, 08:55 AM
Year/Make/Model: 2000 Kawasaki VN800 Classic
I've used JB Weld with good results as well.
Big G
Gerry Langwell (Big G)
Albuquerque, NM
2000 VN800 Classic
Big G is offline
Hey there, hi there, ho there! CRU New Member Introductions 3 09-15-2016 02:11 PM
Can someone please tell me what this is? ffron69 General Vulcan Talk 0 05-20-2015 09:41 PM
tell me about your windshield Flying Dutchman Vulcan 1500 9 03-10-2010 01:32 PM
Tell me about 800 Classic quirks brock29609 Vulcan 800 7 08-18-2009 01:43 PM
tell me about your 500 robuilt Vulcan 500 20 07-14-2009 07:42 PM
