Strange Carb Issue - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 21 (permalink) Old 09-03-2017, 11:08 PM Thread Starter
Year/Make/Model: 96 Vulcan 800
Color: Black
Question Strange Carb Issue
Hello All,
New to the forum, and hoping someone can suggest something that may be an issue on my bike.
96 Vulcan 800
7700mi
Exhaust is debaffled, and I did the "Scooterize mod" Attached is a picture of the result.
Factory needle, using a 52 pilot and a 170 main jet. I have adjusted the air/fuel screw as few as 1 turn and as many as 4 or 5, this issue doesn't seem to go away.
I have gone through the carb again and again, but I have one issue at this point that is blowing my mind. In different gears and at different times, I roll onto the throttle and when I am at roughly 25%, the bike starts breaking up. popping/spitting/sputtering and if I hold the throttle at that point, it just continues to do so and never clears up. It also wont really accelerate anymore until I go to probably 75% throttle, at which point it clears right up and pulls like a bat out of hell.
Additionally, when I am on the highway it seems to be even worse in 5th gear, which is problematic because I find that 25% is sort of a sweet spot for 70-75mph.
Thanks in advance.
Name:	Air Cleaner (3).jpg
96 Vulcan 800
Kuryakyn Hypercharger, Viking Hard Bags
DespicableDan is offline
post #2 of 21 (permalink) Old 09-04-2017, 03:05 AM
There are two ideas:
1) Vacuum leak or a fuel petcock issue.
2) Too small fuel level in a float chamber which could be the result of first idea.
tehnis is offline
post #3 of 21 (permalink) Old 09-04-2017, 10:49 AM Thread Starter
Color: Black
Last night before making this post I took the carb off and checked the float level, as it was the one thing that I had not yet checked.
It was set around 17-18mm so I adjusted it down closer to 16.5.
Also I would think that if it was starving for fuel that I wouldn't be able to go full throttle and have it clear right up.
I will investigate the fuel petcock problem.
96 Vulcan 800
post #4 of 21 (permalink) Old 09-04-2017, 12:12 PM Thread Starter
Color: Black
Just an update:
As a trial to see if the petcock was the issue, I pulled the vacuum line off the petcock and plugged it, and went on a short ride with the petcock in the prime position.
My thought is that if the petcock not flowing correctly was the issue, being the prime position should just supply fuel nonstop independent of any vacuum.
Results were basically the same, rides decent around town, but when you get on the highway the issue becomes more pronounced and it just runs horribly.
96 Vulcan 800
post #5 of 21 (permalink) Old 09-04-2017, 01:07 PM
trainermb's Avatar
Year/Make/Model: 2007 Kawasaki Vulcan 900 Classic LT
Displacement/CC's: 900
Color: Black & Silver
If you have pulled them, what is the condition of the spark plugs?
"Don't force it. Get a bigger hammer."
- William Shakespeare
trainermb is offline
post #6 of 21 (permalink) Old 09-04-2017, 01:31 PM Thread Starter
Color: Black
I may go ahead and replace them. I installed new ones about 1400 miles ago when I first got the bike, perhaps with all the changes I've made to the intake/exhaust I should have replaced them already.
96 Vulcan 800
post #7 of 21 (permalink) Old 09-04-2017, 01:44 PM
You may have some spark scatter due to vibration.
Try jumpering the two wires at the sidestand switch together and try again.
sfair is offline
post #8 of 21 (permalink) Old 09-04-2017, 01:55 PM
trainermb's Avatar
You may be right, but I was asking about the color and condition of the plugs as a clue to whether this is, in fact, a carburetor issue.
post #9 of 21 (permalink) Old 09-04-2017, 03:56 PM Thread Starter
Color: Black
Thanks for the tips.
I will check out those two items.
96 Vulcan 800
post #10 of 21 (permalink) Old 09-05-2017, 02:03 AM
Just an update:
I had similar problems on highway when I had a vacuum leak at manifold. The rubber holder which connects the carb to the manifold was not sealed. (The rubber gets old and hard. I ordered new one.). The engine got warm and started to suck outside air. I got lean and loss of power and extra heat in pipes. Try to check any vacuum leak on hot engine. Take some carb cleaner or starting fluid and carefully spray over Your manifold when the engine is idling. If rpms are changing, everything is trivial.
tehnis is offline
Strange engine issue Featherstones Engine Work 2 08-05-2018 02:13 PM
strange issue starting bike-battery being drained drwarlock Vulcan 1500 1 07-10-2016 12:14 AM
Carb Cleaning: What to Dip and Is Carb Repair Kit necessary? rileyyh Vulcan 500 9 05-13-2016 07:41 PM
Strange issue with engine please help Gajju Vulcan 900 8 08-29-2015 08:49 AM
Strange gas issue okboyd Vulcan 1500 1 10-26-2008 03:37 PM
