Petcock, replace ore rebuild - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 08-02-2017, 09:08 PM Thread Starter
Year/Make/Model: 2006 Kawasaki Vulcan 800 Classic
Displacement/CC's: 800
Petcock is leaking on my 97 Vulcan classic. Do i replace it , or rebuild?
I'm happy to take it apart, clean and repair. .... but would it be better to replace?
Thanks !
zedteamk2 is offline
post #2 of 6 (permalink) Old 08-03-2017, 12:16 AM
Not worth to rebuild. Just replace it with a Suzuki LT80 petcock for 5$
https://www.ebay.com/sch/i.html?_fro...etcock&_sop=15
Replaced mine last week. Works perfectly. I only had to shorten the knob. (Depends on which type You buy.) Cheaper and longer ones work just from the box Everything else works like a charm
tehnis is offline
post #3 of 6 (permalink) Old 08-03-2017, 09:55 PM
If you want to retain OEM features, replace. Rebuilds are very hit and miss.
sfair is offline
post #4 of 6 (permalink) Old 08-11-2017, 10:53 AM
I tried a rebuild which didn't work, ended up replacing.
1996 800A
gun4u2 is offline
post #5 of 6 (permalink) Old 09-09-2017, 06:54 PM Thread Starter
Finally got around to putting in the cheap replacement.... I see what you mean about shortening the knob. Probably do that tomorrow.
The fuel intake tube/filter is a lot shorter. Can i assume that reserve is going to be less? I try to never let it get to that, but good to know.
post #6 of 6 (permalink) Old 09-10-2017, 09:54 AM
Sure, the reserve will be a bit shorter How much? I never got a chance to measure. Actually, I never reach it anyway by doing 120 miles on a highway till I tank.
It would be great if someone could share their experience.
tehnis is offline
Petcock Rebuild Kit Works (with a simple modification) KingDeuce Vulcan 800 4 10-13-2015 05:44 PM
Rebuild or Replace stormrdr66 Engine Work 5 04-03-2012 12:26 AM
Petcock won't turn off, rebuild kit? Ronmold General Vulcan Talk 4 11-19-2011 07:22 AM
Petcock rebuild... Comet_1500 Vulcan 1500 0 10-11-2011 10:11 AM
Replace Petcock Meauxx Vulcan 1500 0 04-17-2011 12:59 PM
