Chain/Sprocket matchup - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 07-25-2017, 07:54 PM Thread Starter
Year/Make/Model: 99 Kawasaki Vulcan 800 Classic
Displacement/CC's: 800
Color: Black/Grey
Hey, guys! I got a DID 530VX chain and sprocket set for my '99 800 Classic. Once I had everything apart, I decided to get a 38T rear sprocket and put that on there. Now that I got all that put back together and the chain on, I've got a ridiculous amount of play in there, even when I put the rear tire all the way back. Am I an idiot, and just didn't realize I needed a different sized chain with a 17/38T sprocket setup, or is there something here I'm missing? Thanks!
Johnny6String is offline
post #2 of 11 (permalink) Old 07-25-2017, 08:19 PM Thread Starter
Color: Black/Grey
Actually, I just realized the chain I got had 114 links, whereas the Classic needs 112 links. I guess I shouldn't trust ebay when it says it's good for my bike. I wonder, can 2 links be removed from there?
post #3 of 11 (permalink) Old 07-25-2017, 11:29 PM
USinPhils's Avatar
Year/Make/Model: 2017
Displacement/CC's: 650
Color: Matte Grey/Black
Yes, you can get a link removal tool. It pushes the pin out and back in. Not sure of cost though, so check prices, may be cheaper to buy a new chain.
Also, make sure you look at motorcycle chain tools, not bicycle tools.
USinPhils is offline
post #4 of 11 (permalink) Old 07-26-2017, 01:29 AM
Beans's Avatar
Year/Make/Model: 2005 Vulcan 800 Classic
Would it be possible to use a punch and hammer to tap out two links and use a master link to reconnect the ends? You would obviously need to be careful that you don't damage the chain, but if the cost of the tool is the same or more than a replacement chain I'd say give it a go the caveman way.
Never argue with a fool: onlookers may not be able to tell the difference.
Beans is offline
post #5 of 11 (permalink) Old 07-26-2017, 05:44 AM
USinPhils's Avatar
Possible? Yes. Recommended? No. The tool is designed specifically for this purpose and I don't know about you but I don't want to be going 70mph+ down the road worrying about the pin wiggling loose and the chain flying through the air. What if the punch slips when you hammer and it bends the sides of the chain? Or you screw up the o-rings?
post #6 of 11 (permalink) Old 07-26-2017, 08:17 AM
Before breaking the chain, You can use a simple angle grinder to cut off a pin head. Is it recommended? Yes! Because most of cheap chain breaking tools (under 100$) are too weak to depress the pins. They will be good only for joining chains.
tehnis is offline
post #7 of 11 (permalink) Old 07-26-2017, 09:47 AM
Beans's Avatar
That is basically the exact method I was thinking, though I never even thought about using an angle grinder.
Again, if the cost of a replacement chain is less than the cost of the chain breaker then I say either just order the correct replacement chain, or try this method to remove a couple of links and use a master link. As long as you take your time so you don't damage any of the other links, it should be perfectly safe.
Beans is offline
post #8 of 11 (permalink) Old 07-29-2017, 10:09 PM
Evilwestsidefan's Avatar
Year/Make/Model: 1997/Vulcan/Classic
Color: Blue
Most bike shops can do that for you. Why did you go to a 38 tooth sprocket.
Evilwestsidefan is offline
post #9 of 11 (permalink) Old 07-30-2017, 02:06 AM
Beans's Avatar
17/38 is an almost identical sprocket ratio to 18/40, so I assume that's the logic. Also, based on the Russian Wolf website, a 17/38 sprocket combo requires a 112 link chain.
Beans is offline
post #10 of 11 (permalink) Old 07-30-2017, 07:47 AM
By the way, smaller diameter sprockets make chain wear off faster.
tehnis is offline
Chain and sprocket change Keithdb Vulcan 800 33 01-04-2016 06:50 PM
Chain and sprocket change Keithdb General Vulcan Talk 2 11-09-2012 07:22 PM
Sprocket/chain replacement questions... Pa. Vulcan General Vulcan Talk 0 03-21-2011 11:25 AM
Sprocket/Chain Options C1rider Vulcan 500 10 06-29-2010 09:41 AM
sprocket and chain Binner Vulcan 800 3 10-10-2009 04:17 PM
