Seems to rev hi - Kawasaki Vulcan Forum : Vulcan Forums
 7Likes
post #1 of 14 (permalink) Old 07-04-2017, 05:53 PM Thread Starter
Year/Make/Model: 95 kawasaki vulcan vn800a
Displacement/CC's: 800
Color: Red
Seems to rev hi
Not familiar with these bike too much. Seems at 45 to 50 in 5th gear is a high rpm. No tach so unsure. To the point riding buddies are telling me to shift up (granted the are riding full size HD) Notice as well that when I throttle heavy it pops and farts. Have not gone on HWY as new to the street. Any ideas or suggestions would be awesome or if it is just the bike. It's a 95 vulcan 800
Rcalileo is offline
post #2 of 14 (permalink) Old 07-05-2017, 07:08 AM
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Color: black
Mine is also from '95 and as far as I remember the rear gear ratio allows this high rpm. Stock, the bike has 16T front and 46T on the rear sprocket.
I have changed to 18T front and 42T rear. There are many variants of aftermarket sprockets on the market, depends on each preferences.
Rcalileo likes this.
marcelm is online now
post #3 of 14 (permalink) Old 07-05-2017, 07:52 AM Thread Starter
Color: Red
Ok thank you, so it's me and not the bike. I'm going to change the plugs as well. May help with when throttling heavy the popping stops
Rcalileo is offline
post #4 of 14 (permalink) Old 07-05-2017, 08:04 AM
marcelm's Avatar
Color: black
Just change the sprockets and you will be fine.
post #5 of 14 (permalink) Old 07-05-2017, 11:28 AM Thread Starter
Color: Red
Any recommendations where to purchase. Guessing should change chain as well while it's out. Using the 18t and 42t would it still be factory length and pitch chain? Thanks again for your help
Rcalileo is offline
post #6 of 14 (permalink) Old 07-06-2017, 02:42 AM
marcelm's Avatar
Color: black
You can just use google to search, or ebay, or you can go to your local dealer.
https://www.ebay.com/sch/Motorcycle-...2611453/i.html
If change sprockets, you should change also the chain. Don't remember if the same length, but if you buy a new chain, it will be long enough to cover any extra length.
There are many discussions on the forum regarding the sprockets variants.
Good luck.
post #7 of 14 (permalink) Old 07-06-2017, 08:49 AM
rick's Avatar
When you say it 'pops and farts" do you mean its popping back through the intake? This is a sign its running too lean. Does it have any mods such as modified or after market intake, air filter? Are the exhaust pipes stock/quiet? As for the high revving, as long as the clutch is not slipping, this is normal for these bikes, they red line at I think 9200 rpm, hit the rev limiter. Compared to large V-twins they do rev higher.
2005 800 classic
2012 Voyager ABS
rick is offline
post #8 of 14 (permalink) Old 07-08-2017, 02:36 PM Thread Starter
Color: Red
Threw the exhaust it pops but only at heavy trottle. I have changed the plugs Recently but because of work and rain havnt gone for a ride. Wife took it out and said runs well. Only after market I know of is the pipes.
Every day is a great day. Its just better when you can ride it
Rcalileo is offline
post #9 of 14 (permalink) Old 07-08-2017, 02:50 PM
The OEM pipes hide decel popping very well. It's normal to hear with aftermarket pipes. Using a fuel controller or getting the ECU reprogrammed by Ivan will minimize the effect.
I'm gone!
crazyriderguy is offline
post #10 of 14 (permalink) Old 07-08-2017, 05:46 PM
Peg
Peg's Avatar
You have no ECU, so don't worry about sending that to Ivan, and you have a carb, so can't use a fuel controller either.
Here's a link to Russian Wolf's modification pages, for a wealth of excellent information about the 800... The Wolf's Bike Shop; just how far do you trust me?
Paul (Peg) Elliott
Peg is offline
97 Classic backfires and runs rough on what seems to be one cylinder beween 40-60 Sty9 Vulcan 1500 1 08-01-2011 08:54 AM
1996 800 seems to chug while coasting crowley1 Vulcan 800 1 07-06-2011 10:33 PM
seems to run hot????????????? kaweerdr010 Vulcan 1700 10 07-06-2011 07:49 AM
Seems to be flooding but it's fuel injected??? fifty9singlecab Vulcan 1500 6 06-09-2011 10:40 AM
My reserve tank capacity seems high. Is this right? Kaze Vulcan 500 7 08-08-2010 11:43 PM
