Hotter plugs on my 800 - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
post #1 of 20 (permalink) Old 06-05-2017, 01:45 AM Thread Starter
I have a 98 vn800b My rear plug was always running a bit darker than desirable. I read Russian wolfs wright up on switching from the cr7e to the hotter Cr6e he says that lots of people have done this and no one has had any issues, I haven't been able to find any one that can conferm actually doing this just qouting Russian wolf. Is switching both plugs safe for the motor, I don't want to burn up my bikes motor. Has any one made the switch to Cr6e plugs and how has it been.
bluegoose95401 is offline
post #2 of 20 (permalink) Old 06-06-2017, 01:57 AM
Hi!
When I bought my bike, I found out that the previous owner did that. But even after that both plugs were in terrible condition. Burned black with wrong gaps and never maintained. I adjusted my valves, cleaned and adjusted my carb, and actually switched back to CR7E. To be honest, I have no problem since that and I see no reason not to follow the original service manual. In my opinion if everything is OK there should not be a big difference what spark plug is being used in a second cylinder. Yes, it's a little bit hotter, but both plugs (CR7E and CR6E) should have no problem with those second cylinder temperatures.
What to say, just test Yourself, what is better for You. You can not burn Your engine anyway: )
tehnis is offline
post #3 of 20 (permalink) Old 06-06-2017, 10:12 AM
What do you mean by "a bit darker"?
Post a picture of both plugs would help.
sfair is offline
post #4 of 20 (permalink) Old 06-06-2017, 03:58 PM Thread Starter
I don't have a picture right now I could try to grab one later.
post #5 of 20 (permalink) Old 06-06-2017, 04:01 PM Thread Starter
Originally Posted by tehnis View Post
Hi!
I switched both plugs out to the hotter plug, it's warming up better and seems to be running fine. I just don't want to burn up the motor and I get paranoid about those things. Especially since money is super tight and getting a new bike is not an option
post #6 of 20 (permalink) Old 06-06-2017, 05:24 PM
Installing hotter plugs just "covers up" an existing problem.
It ran fine for the first 15 years of its life without them, and so it should continue.
sfair is offline
post #7 of 20 (permalink) Old 06-08-2017, 06:10 AM
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Displacement/CC's: 800
Color: black
With the original plugs (CR7E), I had always problems with the rear one.
Since 3 or 4 years, I have changed the rear one to CR6E => no issues anymore.
Maybe we cover an existing problem, but fact is that the engine runs well and plugs color is OK. Could be something wrong in design ?? ..... too many VN800's has this issue.
marcelm is offline
post #8 of 20 (permalink) Old 06-08-2017, 06:38 AM
What problems exactly did You have?
tehnis is offline
post #9 of 20 (permalink) Old 06-08-2017, 06:43 AM
marcelm's Avatar
Color: black
I suppose you are asking me. If not , sorry...
When cold and starting the engine, first 2 min were running OK, but afterwards, the rear cylinder stops, plug complete black and wet.
marcelm is offline
post #10 of 20 (permalink) Old 06-08-2017, 08:06 AM
The hotter plug is covering up two problems:
1. Fuel tap that is leaking, or
2. Carb that need work, or
3. Both.
sfair is offline
Greetings from hot and hotter Texas! pljenkins522 New Member Introductions 4 07-22-2017 12:10 PM
Bike temperature feels much hotter than in the past 10grandstan Vulcan 500 2 09-30-2015 08:44 AM
Engine backfires and exhaust seems to get hotter than normal rjan3es New Member Introductions 3 08-31-2015 11:28 AM
Why run a hotter spark plug vs OEM? Juancho Vulcan 500 6 09-02-2013 06:35 PM
Hotter Plug for the 500 steve1431 Vulcan 500 0 09-01-2008 09:46 AM
