Exhaust leak at the header?? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 05-30-2017, 07:06 AM Thread Starter
Hatrick3's Avatar
Year/Make/Model: 1999 Kawasaki Vulcan 800 Classic
Displacement/CC's: 800
Color: Black/red
My 99 800 classic keeps getting an exhaust leak right at the front header pipe. I had been noticing an exhaust leak near the front of my bike and one day I noticed that the flange nut was almost half way off on one of them. I tightened the nut down and the leak went away after riding for a bit the leak came back. Tighten it again it goes away as soon as the bike heats up it comes back. Anyone else ever have this problem? If so how do I fix it? Is there a gasket in there that can go bad??
Thanks for any help.
Hatrick
Life's a ride do it on a Vulcan!!
Hatrick3 is offline
post #2 of 6 (permalink) Old 05-31-2017, 05:34 AM
rick's Avatar
There is a crush gasket on them. My rear pipe gasket needs replaced every couple years, its about due now. I can usually tell when it needs done because I start getting the exhaust popping when decelerating. I put split lock washers on mine to keep the nuts from backing off as much.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 6 (permalink) Old 05-31-2017, 06:28 AM Thread Starter
Hatrick3's Avatar
Color: Black/red
Thank you for the reply... I'm getting a new gasket and nut.
Hatrick3 is offline
post #4 of 6 (permalink) Old 05-31-2017, 06:33 AM
btom's Avatar
Year/Make/Model: '05
you're in vermont, you going to americade in lake george ny? every been there?
btom is offline
post #5 of 6 (permalink) Old 05-31-2017, 12:00 PM Thread Starter
Hatrick3's Avatar
Color: Black/red
Maybe when is it? I'm only about 2 and a half hrs from lake george. I'm still fairly new to street bikes grew up on dirt bikes so the basics are all there. I can ride just getting used to the different riding style
Hatrick3 is offline
post #6 of 6 (permalink) Old 06-13-2017, 10:27 AM Thread Starter
Hatrick3's Avatar
Color: Black/red
It was the crush gaskets!! Replaced them and perfect now was a very simple job to do also took me all of about an hour to do both! Thank you for the advice Rick!! cheers!
Hatrick3 is offline
Muffler won't fit exhaust header. dabs General Vulcan Talk 4 01-30-2016 05:25 AM
Exhaust Header bolt+acorn SimpleJack239 Vulcan 1600 2 09-21-2015 09:40 PM
rear header oil leak madhatter4119 Vulcan 1500 2 06-30-2014 09:12 PM
Left exhaust is bluing- but NOT at the header DustyRags Vulcan 500 5 04-18-2013 11:26 AM
Exhaust header pipe leak BgDddySUM General Vulcan Talk 0 10-11-2011 01:22 PM
