Is my pre-load adjusted all the way up? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 05-08-2017, 07:17 PM Thread Starter
Year/Make/Model: 1997 Kawasaki Vulcan
Displacement/CC's: 805
Color: Red
My '97 VN800A seems to be a little soft. Granted, I'm 6'2" and 240lbs, so I'm no lightweight, but it seems like the bike sinks a bit too much when I saddle up.
I was reading about the preload adjust and figured I'd give the adjustment a shot, but this is what I found:
I'm assuming it's already at the highest level or has the most preload?
Should I be looking for a replacement shock and/or spring (if that's even available)?
gtrdave43 is offline
post #2 of 8 (permalink) Old 05-08-2017, 07:23 PM
Year/Make/Model: 2013 Voyager
Color: Pearl White/Titanium
That preload is set as stiff as it will go. Can't give you advise on if there's another shock or spring available hope someone can answer that for you
MidIAVoyager is offline
post #3 of 8 (permalink) Old 05-08-2017, 08:14 PM
Those shocks are 20 years old. By all means, do a bit of research & choose some that will accomplish what you're after. Even stock replacement, if available will be an improvement.
Sent from my SM-G900V using Tapatalk
warrbucks is offline
post #4 of 8 (permalink) Old 05-08-2017, 10:34 PM
Prelod will not make it harder. It will just prevent it from bottoming out. Say, does it bottoms out even on maximum!? Are You sure? If yes, it needs a replacement. If no, its normal.
tehnis is offline
post #5 of 8 (permalink) Old 05-12-2017, 11:49 AM
Year/Make/Model: 2002/ Kawasaki/800 Classic.
Displacement/CC's: 800CC
Color: Dark Purple and silver.
Could someone please tell me where this adjustment is on my 2002? I can not even find it in the manual or the shop manual. Unless i am missing something. I like mine set the mid adjustment on all my mono shock bikes. Im 5'8 and 180 and never have a passenger and being a bit lower suits me better. That also looks like a real pain to get to to adjust. Maybe?
Respects
Harry
harryinny3 is offline
post #6 of 8 (permalink) Old 05-12-2017, 12:13 PM Thread Starter
Color: Red
No, it doesn't bottom out, even with me and my wife on board, but it just seemed to be traveling farther than I expected. I guess it's normal, though. Looks like a decent replacement shock is ~$450, so that will wait a while.
harry, I removed the right side cover and compartment to get to it. Took about 5 minutes. I hear that adjustment is made via a long bar/screwdriver/rod/etc...and a hammer and is best accomplished with the bike on a stand, raising the rear wheel and taking load off of the shock.
post #7 of 8 (permalink) Old 05-12-2017, 12:59 PM
It's not a good idea to use a hammer. You can damage that ring. If You could lift up the bike or somehow hang it on slings, You could turn the ring with any other much gentle tool. Just drop some oil behind the ring. I used a simple bicycle wrench which has a hook.
Bicycle Bike Lock Ring Remover Bottom Bracket Repair Spanner Wrench Tool | eBay
tehnis is offline
post #8 of 8 (permalink) Old 05-12-2017, 01:05 PM
btom's Avatar
Year/Make/Model: '05
i tried using a big heavy duty screwdriver and hammered at the shock, didn't budge it, so removed the shock to adjust it to #4, there are 7 setting, you only turn it 1 way, after #7 (hardest) it drops back down to #1 again (lightest setting)
btom is offline
Rear Suspension Pre-Load Cpt.Evil Vulcan 650 S 75 Yesterday 03:44 AM
Rear Shock Pre-Load Adjustment 17A General Vulcan Talk 2 06-04-2018 07:50 AM
Pre load gsmacka Vulcan 800 1 08-11-2017 12:53 AM
Suspension Pre-Load Setting? Romper Vulcan 900 14 11-19-2014 09:24 AM
adjusted my valves tattooer Vulcan 500 5 03-16-2014 04:12 PM
