LED 1157 Taillight - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
post #1 of 47 (permalink) Old 05-06-2017, 07:10 PM Thread Starter
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
LED 1157 Taillight
I am looking at (2) of these 1157 LEDs below for taillights, what do you think?
see Item: GEN10CLUSTER
Motorcycle LED Light Bulbs
1" Diameter 16 LEDS Red
my '05 800 (2) stock 1157 bulbs 1 5/8" apart center to center
btom is offline
post #2 of 47 (permalink) Old 05-07-2017, 05:34 AM
Hi!
Do You still have a stock tail light? If Yes, then how will You illuminate the license plate? With red LEDs?
Anyway, even if You choose white, these type of LEDs are straight directional and will not illuminate the license plate. I would go for SMD. They are much brighter, cheaper and fit as expected.
I'm using this type of SMD LEDs.
Cheap and definitely worth the money
tehnis is offline
post #3 of 47 (permalink) Old 05-07-2017, 09:29 AM Thread Starter
btom's Avatar
ya i have stock red lense, so you got white leds in a red lense? why not red leds in a red lense? does it matter if plate shines in red? what's smd stand for
btom is offline
post #4 of 47 (permalink) Old 05-07-2017, 09:58 AM
Yes, why not? Ordinary standard bulbs are also white I see no reason why someone should need to double-red the light? Besides, it will result in poor efficiency and You will be loosing some lumen. It means that white LEDs by default will shine brighter than red LEDs through that red glass.
Better check the regulations in Your country/state what they say about red license plate lights. In Europe there's a strict rule to have only white bulbs there. Sometimes even LED's (which are more blue than white spectrum) are not allowed.
Read oabout SMD here.
tehnis is offline
post #5 of 47 (permalink) Old 05-08-2017, 07:53 AM Thread Starter
btom's Avatar
so I was googling and say this Tail Light Bulb Upgrade
so I went to the auto parts store and bought (2) 2357 bulbs
are 2357's ok?
btom is offline
post #6 of 47 (permalink) Old 05-08-2017, 09:00 AM Thread Starter
btom's Avatar
i put in the (2) 2357 bulbs, and the taillight on the 2357 is same lumens as the stock 1157 bulb, but the 2357 brake light part is slightly brighter by a bit than the 1157, the (2) 2357 bulbs I got at NAPA are Wagner bulbs
btom is offline
post #7 of 47 (permalink) Old 05-08-2017, 09:12 AM
Should be OK
tehnis is offline
post #8 of 47 (permalink) Old 05-08-2017, 10:14 AM Thread Starter
btom's Avatar
i read some guy reviewing LED bulbs for taillights and he said the 1157 incandescent bulbs are just as good as the LEDs and maybe even better, so then this morning I was googling and saw a post on the 2357 bulbs, I like the 2357 , they were only $1.88 a piece
btom is offline
post #9 of 47 (permalink) Old 05-08-2017, 10:54 AM
In my opinion there's only one reason why someone should switch to LEDs. They consume considerably less power than incandescent bulbs. More efficiency, less heat. It means less load on alternator as well as less fuel consumption. I don't need an extra brightness on my rear end. I just need ordinary functionality with less power, Thats all. Therefore I prefer those cheap Chinese SMD LEDs I mentioned previously.
I even changed my front H4 bulb with some kind of day running light LED for 4$. Sure, it's not good enough for a normal night ride, but as day running light it's perfect for me.
tehnis is offline
post #10 of 47 (permalink) Old 05-08-2017, 11:17 AM Thread Starter
btom's Avatar
I clicked on that LED link for $4, how come you can't use it for hi/low beam and for night time riding? I put in a 3700K Philips Xtreme Vision +100% H4 bulb, haven't tried it yet, I just turned the key on to see if the Philips bulb works, should I buy that 6000K LED Hi/Lo bulb? Will I like it? Why would it be no good for night time? ok wait, I just saw this, it says the Lumen is 800LM, is that a misprint? shouldn't that be like much higher for legal DOT approved?
btom is offline
LED Tail light/Brake light 1157 Pmcfadzen Vulcan 1500 10 05-08-2017 01:12 PM
Custom Dynamics - Dynamics Ringz, 1157 or baz-3? tajaii Vulcan 900 1 03-21-2016 06:25 PM
1034 vs 1157 Al Vulcan Vulcan 500 2 02-24-2014 04:24 PM
1157 LED Bulbs... atineo1982 Vulcan 900 14 03-28-2012 12:35 AM
