Idle idle idle - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 04-22-2017, 03:41 PM Thread Starter
Derek's Avatar
Year/Make/Model: 1997
Displacement/CC's: 800
Color: Black
Idle idle idle
Ok so as u can see by my before and after photos I have done some mods to my bike obviously the stock petcock has a vacume but the sportster tank does not so when I switched it all out on my first ride I got tons of fuel in my air filter case so I took it apart to check the float needle even tho the guy I got the bike from just rebuilt them .... to my amaze he didn't lie and everything was brand new so put it all back together no more fuel in the air box ...... BUT now when I'm in neutral or engage the clutch my Rpm go wayyyyy up before you suggest idle screw done that no luck before u say fuel screw on the carb done that I'm sitting at about 1/2 screw out and still high as ale ... ive heard I have a vacume leak possibly or a timing issue but I don't know where to look because my carb boot into the intake is good so what could be my issue any help would be appreciated
Derek is offline
post #2 of 10 (permalink) Old 04-22-2017, 07:08 PM Thread Starter
Derek's Avatar
Color: Black
20 views no help come on gentlemen
Derek is offline
post #3 of 10 (permalink) Old 04-22-2017, 07:39 PM
You didn't mention anything about the choke. What condition is it in?
I'm gone!
crazyriderguy is offline
post #4 of 10 (permalink) Old 04-22-2017, 07:42 PM Thread Starter
Derek's Avatar
Color: Black
My fault forgot to mention choke is good and I'm I never use it anyway to warm up just the grips which also brings me to another point when I start it up runs good as soon as is warms up or I give it throttle it never idles low again and I checked the cables they do not stick at all
Derek is offline
post #5 of 10 (permalink) Old 04-22-2017, 07:59 PM
Could the butterfly plate in the carb be sticking? Take the air cleaner off and watch for smooth movement.
When you reassembled the carb, did you get the main needle diaphragm seated good? The VN750 uses the same carb as the VN800. I had rebuilt mine and the rubber diaphragm was a real PITA to seat properly. However, my bike would accelerate, but the RPM's would stop climbing after a certain point.
I would spray some WD40 around the boots and see if the RPM's fluctuate any. Those boots are VERY specific on how they are reassembled.
Not a lot to point to on carb'd bikes. I don't believe timing is involved here since timing can't be altered.
I'm gone!
post #6 of 10 (permalink) Old 04-22-2017, 08:11 PM Thread Starter
Derek's Avatar
Color: Black
I'll try that tomorrow I'll get it warmed up and piss the neighborhood off without the air box and make sure it works as it should I'll report tomorrow
Derek is offline
post #7 of 10 (permalink) Old 04-23-2017, 12:24 AM
rick's Avatar
Was the port for the petcock vaccum plugged when the Sportster tank was installed? Its on the top of the carb, as you look at it mounted on the bike, its in the 12 o'clock position.
2005 800 classic
2012 Voyager ABS
rick is offline
post #8 of 10 (permalink) Old 04-23-2017, 12:40 AM
I nearly asked that same question earlier. However, the parts diagrams didn't show a vacuum line coming from petcock.
I'm gone!
post #9 of 10 (permalink) Old 04-23-2017, 06:06 AM Thread Starter
Derek's Avatar
Color: Black
Yea it was part of he fuel separator but I took all that off and plugged up everything I even capped off that vaulve on the carb itself so we are all good there
Derek is offline
post #10 of 10 (permalink) Old 04-23-2017, 08:49 AM Thread Starter
Derek's Avatar
Color: Black
Update .... clamps on the carb boot where to loose tighten down open up the fuel screw runs like a champ now thanks for all yalls help
Derek is offline
Why are my idle RPM's periodically not coming to full idle when stopped ? mark482 Wrench Heads 0 08-25-2018 06:39 PM
'help with resetting fuel jets, idle mixture screws and main idle screw' Riz Vulcan 500 2 01-28-2013 09:07 PM
help with resetting fuel jets, idle mixture screws and main idle screw Riz New Member Introductions 3 01-21-2013 08:19 PM
Cold Idle vs. Warmed-up Idle C1rider Vulcan 500 12 07-10-2010 07:50 AM
erratic idle speed howard Vulcan 900 1 08-29-2008 04:34 AM
