Oil screen plug - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By btom
post #1 of 6 (permalink) Old 04-13-2017, 09:24 PM Thread Starter
Oil screen plug
Anyone have tricks to open oil screen plug? So far I've only managed to start to round the plug using a box end wrench.
1996 800A
gun4u2 is offline
post #2 of 6 (permalink) Old 04-14-2017, 05:04 AM
Try a pneumatic (or electric) impact wrench tool in combination with heat gun. You will have a success in 99%.
EDIT
Heat it up and let it cool down couple of times, but do not heat it up too much in first step. 2-3 times of 100-150 degrees of Celsius will be enough.
There's a drawback, too. You will need a new gasket.
tehnis is offline
post #3 of 6 (permalink) Old 04-17-2017, 06:08 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
don't use the open end of a box wrench, that is sure to round the corners, use the closed 6 point end, not a 12 point but a 6 point
BrokenChef likes this.
btom is offline
post #4 of 6 (permalink) Old 04-17-2017, 06:10 AM
btom's Avatar
and if you have any 12 point box wrenches, toss em and buy only 6 point ones, and use metric, not standard
btom is offline
post #5 of 6 (permalink) Old 04-20-2017, 07:40 AM Thread Starter
Thanks for the input. Time to get new tools. Will try these methods next oil change.
gun4u2 is offline
post #6 of 6 (permalink) Old 04-20-2017, 09:10 AM
On the farm, sometimes we encounter a stuck bolt. One quick and easy attempt to remove it is ( we used what we had) to grab a 3 lb hand sledge hammer and give the bolt a nice rap on the head. Bear in mind you do not want to hit your bolt or plug hard enough to break the engine case. Just sometimes a rap with a solid hammer would break a bond. A regular hammer might work just as well. Just don't hit it too hard, just a nice solid tap.
If the plug is recessed into the block, you could get a large punch or something solid to make an extension. 1/2" or 3/4" socket extension comes to mind. Just don't hit where you shouldn't and please don't hit too hard.
This method doesn't always work, but I have seen it and have done it myself enough that we will try it before the torches and other stuff come out.
To understand true love, lock your dog and your wife in the trunk of your car for an hour and then see which one is glad to see you when you come back.
2011 900 Classic LT
Frazzy is offline
Oil change video (includes oil screen check) Zzman Vulcan 900 6 05-01-2018 12:48 PM
can i use the screen plug to drain oil indigobluex Vulcan 900 5 09-03-2012 09:15 PM
Help with baffle screen/plug mjtski Vulcan 900 2 07-27-2011 11:45 AM
Oil screen poffutt Oil and Lubrication 7 05-07-2009 11:19 AM
First oil change ... screen method rpgpgmr Vulcan 900 13 10-06-2008 12:31 PM
