!@#$! master cylinder screw - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By gtrdave43
  • 1 Post By rick
post #1 of 7 (permalink) Old 04-12-2017, 10:56 AM Thread Starter
Year/Make/Model: 1997 Kawasaki Vulcan
Displacement/CC's: 805
Color: Red
[email protected]#$! master cylinder screw
I installed the new front brake pads last night and that was a fairly quick and easy job, EXCEPT that one of the two screws on the master cyl. cover would not budge and no matter how many different screwdrivers I tried, the head became stripped.
I ended up drilling it out and extracting it, doing zero damage to the threads and the master cylinder itself, thankfully.
This is not my first rodeo...
Thanks to the influence of my very mechanically minded late-father and his penchant for keeping old nuts, bold, screws, etc...I found an almost identical replacement screw (same head taper, same threads, similar length) in one of my parts bins.
So, after a few days of maintenance (new rear tire, inspect and clean rear brakes, new K&N air filter, oil and filter change, new front brakes) I was finally back on the road this morning, with no spare parts to be found.
Except for that stupid m/s screw...
Dollarbill44 likes this.
gtrdave43 is offline
post #2 of 7 (permalink) Old 04-12-2017, 11:05 AM
rick's Avatar
You are not the 1st to have this problem. The screws are not actually phillips heads, but are JIS heads. They are close to being phillips, but not quite. You can get a decent set of JIS screw drivers from Amazon at a decent price. A good investment.
MN-Rider likes this.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 7 (permalink) Old 04-12-2017, 12:38 PM Thread Starter
Color: Red
I like tools and I really like having the right tools, so I'll look into getting a set, thanks!
post #4 of 7 (permalink) Old 04-12-2017, 07:48 PM
BOTSpring Winner 2017
Shores's Avatar
Year/Make/Model: 1995
Displacement/CC's: 800
Color: Gold
The screw driver in your tool kit is JIS. Japanese Industrial Standard. That's what I use.
Shores is offline
post #5 of 7 (permalink) Old 04-12-2017, 08:21 PM
btom's Avatar
Year/Make/Model: '05
you need one like this:
VESSEL Megadora 900 Series +P2x100 JIS +2 Cross Point Tip Screwdriver New Japan | eBay
btom is offline
post #6 of 7 (permalink) Old 04-12-2017, 10:57 PM Thread Starter
Color: Red
The tool kit was missing from the bike when I bought it.
post #7 of 7 (permalink) Old 04-13-2017, 08:02 AM
Venom831's Avatar
Year/Make/Model: 2002 Vulcan 500
Displacement/CC's: 500
Color: Maroon
I found a toolkit with all the tools, and the bag, from eBay for $20 with shipping.
Venom831 is offline
difference between a clutch master cylinderand brake master cylinder daremoe63 Vulcan 1500 6 05-28-2015 12:18 PM
Kuryakyn Master Cylinder Covers WVVulcan Vulcan 1500 2 03-13-2011 12:10 PM
Help!!!!!!master Cylinder ninja54 Engine Work 4 08-06-2010 10:46 PM
master cylinder piston size? pickandpray Vulcan 500 0 10-03-2009 08:49 AM
