Rear hub issue - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By tehnis
post #1 of 6 (permalink) Old 04-10-2017, 11:22 AM Thread Starter
Year/Make/Model: 1997 Kawasaki Vulcan
Displacement/CC's: 805
Color: Red
Rear hub issue
I'm busy changing the rear tire on my VN800A and when I removed the wheel and looked inside the brake-side hub, I saw this:
See the outside of the center section, where the metal is jagged and sticking out? That's not right, correct?
Is it normal wear? Should I carefully remove the shards and use some emory cloth on the surface to smooth it out a bit?
gtrdave43 is offline
post #2 of 6 (permalink) Old 04-10-2017, 12:11 PM
This part is called a "speedometer receiver". It's for turning a speedometer cable. It looks like somebody could not fit it in the right position after taking the hub apart.
You should inspect the other side of the hub. Is it OK?
Just clean the receiver, grind it gently with some sandpaper to remove those sharp damaged edges and put it in its place correctly. If the opposite side is OK, looks like it will be OK.
WaterFoul likes this.
tehnis is offline
post #3 of 6 (permalink) Old 04-10-2017, 01:23 PM Thread Starter
Color: Red
The other side looks okay, but there's a rubber seal there, so it's hard to get a good look at the receiver end. I'll clean things us and make sure it's okay before reassembly.
post #4 of 6 (permalink) Old 04-10-2017, 01:35 PM
Ok. There's a link that may help.
https://www.motorcyclespareparts.eu/...ub-581154.aspx
Don't forget to apply some grease before assembly!
tehnis is offline
post #5 of 6 (permalink) Old 04-11-2017, 11:33 PM
Agree.
i have a wheel here on my work bench. gettin a new tire on IT because the wheel on my bike is egg shapped.
that slotted piece engages in the speedometer housing, to a corresponding dog. question is why you have metal shavings, so you need to look for that answer.
look inside the housing that holds the back brakes and speedometer gear and cable.
new grease will work wonders. rubber seal in there keeps water out.
1964 Yamaha 90cc - hacked up to loose weight and riden in the dirt
1981 Suzuki 450E - bought new
1983 Suzuki 1100ES - bought new
1983 Yamaha Maxim 750 - resurrected from the scrap pile
1999 Vulcan 800 - resurrected from the scrap pile
Brewster_440 is offline
post #6 of 6 (permalink) Old 04-12-2017, 10:47 AM Thread Starter
Color: Red
Cool, thanks for the help.
I got everything reassembled the other night and all is well.
I cleaned up the hub end of the speedo gear and then cleaned and re-lubed it.
My ride to work this morning was pleasant and uneventful.
Rear wheel hub assbly gartdm98 Vulcan 500 4 06-28-2013 03:01 PM
Rear brake hub for 05 800 Classic Keithdb Wanted to buy or trade Items 2 03-19-2013 07:21 AM
18'' rim on classic rear hub xtreameracer Vulcan 900 7 01-15-2013 09:59 AM
Speedometer/Rear brake hub Keithdb Wrench Heads 4 12-29-2012 09:32 PM
rear brake hub jeff5 Vulcan 500 2 06-01-2011 08:33 PM
