Sidestand switch replacement - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 04-03-2017, 07:13 AM Thread Starter
Hi! Too quiet here. Therefore a simple question.
Is there any cheaper alternatives (like a petcock from Suzuki) for replacing side stand security switch? Actually I don't have it. Seems like I will have to add it for a technical inspection.
It would be nice to have one which fits without heavy adaptation.
Thanks!
tehnis is offline
post #2 of 8 (permalink) Old 04-03-2017, 03:38 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
I found the rad fluid leak on my 800, it was dripping from the filler unit somewhere, so I tightened up a few clamps, I think the leak is fixed, it started leaking after I finished doing the valve clearance checks, next I have to change oil to 10w40 and filter, clean and wax the chain and check tire pressure, I think I'll put in 34F/37R
btom is offline
post #3 of 8 (permalink) Old 04-04-2017, 12:21 AM Thread Starter
So? How does it help my sidestand switch question?
tehnis is offline
post #4 of 8 (permalink) Old 04-08-2017, 12:21 PM
btom's Avatar
do you know what tire pressure I should put in my Michelin tires front and rear? both Michelin Commander II's
btom is offline
post #5 of 8 (permalink) Old 04-08-2017, 09:58 PM
Minimum 40, 42 rear. What I use on my Nomad. Careful, that's hard, slick rubber. Dunlops stick better, Michelin last longer alot longer.
Sent from my SM-G900V using Tapatalk
warrbucks is offline
post #6 of 8 (permalink) Old 04-09-2017, 06:33 AM Thread Starter
Exclamation
btom,
please post Your questions in your own topics with corresponding headings!
This one is about the sidestand electric switch!
Thank You!
tehnis is offline
post #7 of 8 (permalink) Old 04-09-2017, 09:46 AM
What the owners manual sez to.
sfair is offline
post #8 of 8 (permalink) Old 04-09-2017, 10:55 AM Thread Starter
Exclamation
What's wrong with You, people!?
Please someone delete this topic. It lost its meaning!
tehnis is offline
Closed Thread
Sidestand spring replacement Kwazy Kwaka Vulcan 900 5 06-30-2015 11:21 PM
sidestand kill switch Scratche Vulcan 800 14 07-29-2013 03:46 PM
Sidestand switch not working? kswitcheng23 Vulcan 1500 5 05-02-2013 10:48 AM
How To Install Spring For Sidestand REVOMAN23 General Vulcan Talk 4 12-28-2009 09:21 AM
Does the VN500 have a sidestand safety switch? bB2NER Vulcan 500 3 09-08-2009 07:36 PM
