Rear signal bulb - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
post #1 of 15 (permalink) Old 03-03-2017, 09:32 PM Thread Starter
Kiddrock24's Avatar
Year/Make/Model: 2000 Vulcan 800A
Color: Black
Rear signal bulb
What is the model # or size of the rear turn signal bulb for VN 800A? One of my rear signals isn't working and figure its the bulb but can't find a number on the one I pulled or one like it at the auto part store. The service manual wasn't all that clear.
**I found one on ebay I hope will work. It is 12V 23/8 W
Kiddrock24 is offline
post #2 of 15 (permalink) Old 03-04-2017, 01:47 AM
Beans's Avatar
Year/Make/Model: 2005 Vulcan 800 Classic
In my repair manual the bulb is listed as 12V 21W. The 12V 23/8W is for the front turn signals.
Never argue with a fool: onlookers may not be able to tell the difference.
Beans is offline
post #3 of 15 (permalink) Old 03-04-2017, 06:01 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
the rear turn signal bulb housing only have 1 contact prong, meaning if you put in a 23w/8w bulb (which has 2 contact prongs), it will not work
btom is offline
post #4 of 15 (permalink) Old 03-04-2017, 06:35 AM
btom's Avatar
video youtube on 1156 and 1157 difference
btom is offline
post #5 of 15 (permalink) Old 03-04-2017, 09:24 AM
You can refer to BA15S which is the same 1156.
tehnis is offline
post #6 of 15 (permalink) Old 03-06-2017, 10:17 PM Thread Starter
Kiddrock24's Avatar
Color: Black
I must have modded tail lights then because its definitely not the 1157 or 1156. The ones I ordered should be here in a few days so hopefully they will work.
post #7 of 15 (permalink) Old 03-07-2017, 10:07 AM
rick's Avatar
1156 is the size the dealer said is right for the rear of my 05 800B, yours should be the same if stock. You have pic of the light housing? How about the bulb?
2005 800 classic
2012 Voyager ABS
rick is offline
post #8 of 15 (permalink) Old 03-07-2017, 11:07 AM
Year/Make/Model: 2007 Kawasaki Vulcan
Displacement/CC's: 500
Color: black
Wait a minute... Im confused.
So the rear turn signals on the Vulcan 800s don't act as running lights, but the front turn signals do? That seems really weird to me. The whole point of using a duel filament bulb is so that the lights will run constantly at a certain level of brightness, but then be able to run at a higher intensity when a switch is activated. Why would they intentionally install running lights on the front and not the rear? Are you sure you guys aren't getting the front and rear signals mixed up.
Ron Jovi is offline
post #9 of 15 (permalink) Old 03-07-2017, 11:12 AM
Color: Black / grey
Nope all cycle have the front turn signals on all the time and the rear on only to signal a turn.
I believe its a law that you cant have amber lights on the rear of vehicles.
But you can mod the rear turn signals to be red always on running lights.
1995 en500 stock with windshield - 31,000 miles
vulcandoc is online now
post #10 of 15 (permalink) Old 03-07-2017, 11:17 AM Thread Starter
Kiddrock24's Avatar
Color: Black
Here is the bulbs I bought for my rear signals:
12 Volt 23/8 Watt 12 V 23/8 W Replacement Bulb for BULLET STYLE LIGHTS 2FastMoto | eBay
Here is a pic of the housings:
Replacing turn signal bulb 90269 with LED motor_psycho Vulcan 650 S 8 03-14-2017 03:06 PM
Led signal bulb question? Squid4Life Vulcan 1700 8 01-02-2016 05:18 PM
Front Turn Signal Bulb Irish Vulcan Vulcan 900 0 06-21-2010 08:27 AM
Signal Light bulb replacements sailor15 Vulcan 500 0 06-03-2010 11:44 PM
Rear Turn signal help after removing signal minder SCSteve Vulcan 900 5 09-23-2009 08:25 PM
