3 basic electrical questions - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 03-01-2017, 10:30 PM Thread Starter
first, i believe the headlight doesn't come on until the bike starts and is running.
then it stays on when you park, but goes off when the key is shut off.
does that sound correct?
second, bike is in neutral, key on. engine start switch should crank the engine.
if the bike is in gear, you need to pull in the clutch.
third, does horn button sound the horn with the key on and the key off?
1964 Yamaha 90cc - hacked up to loose weight and riden in the dirt
1981 Suzuki 450E - bought new
1983 Suzuki 1100ES - bought new
1983 Yamaha Maxim 750 - resurrected from the scrap pile
1999 Vulcan 800 - resurrected from the scrap pile
Brewster_440 is offline
post #2 of 9 (permalink) Old 03-01-2017, 10:57 PM
ipse_dixit's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan Nomad
Color: Red/Beige
First one is correct, although the bike doesn't technically need to start. It was pointed out to me on another forum, that the light will turn on after the starter is turned and released. It doesn't actually have to start.
Second is correct. I'm unsure about the horn. I want to say, mine only operates with the key on. I'm uncertain and it's a bit late to test it.
2009 Kawasaki Vulcan Nomad 1700
2007 Suzuki C50 Boulevard
2007 Honda Shadow Aero 750
2010 Suzuki GZ250
ipse_dixit is offline
post #3 of 9 (permalink) Old 03-02-2017, 12:14 AM
IMHO, for security reasons the horn should work on ignition key. Does not matter if the engine is on or off.
tehnis is offline
post #4 of 9 (permalink) Old 03-02-2017, 06:59 AM
Color: Black / grey
With key off no horn.
vulcandoc is offline
post #5 of 9 (permalink) Old 03-02-2017, 08:24 PM Thread Starter
my horn works. button in the hand control needed some "massaging"
only works with key on. - yes, it was late last night here when i was messing with it.
Light isn't coming on yet, but i'm still checking. know it was working a couple months ago.
I repainted the hand control aluminum housings, and the headlight as well (and the tank). Have it all put back together, just checking to see if everything is working correctly.
post #6 of 9 (permalink) Old 03-02-2017, 08:25 PM Thread Starter
TY for the info!
post #7 of 9 (permalink) Old 03-02-2017, 10:18 PM Thread Starter
Hi-Beam / Low-Beam switch was not sitting right in the housing control.
contacts not touching.
pulled it apart and cleaned the contacts, a touch of dielectric grease, and got it back in the housing correct.
all good.
key on, no headlight. Hit starter button and light comes on (after it seams the engine cranks over a time or two),
and light is on when engine starts. shut engine off with stop button on hand control and light stays on until the key is shut off. so, i think that's right.
post #8 of 9 (permalink) Old 03-03-2017, 05:47 AM
ipse_dixit's Avatar
Color: Red/Beige
all good.
Yes. That is how mine functions. I'll be cleaning my Nomad up and doing regular maintenance once it warms up a bit. Complete fluid change, since I bought it at the end of last season.
2010 Suzuki GZ250
post #9 of 9 (permalink) Old 03-03-2017, 09:16 AM
Light should go out any time start button is pushed and held.
sfair is offline
Basic Electrical SultanVulcan Vulcan 500 2 04-12-2018 01:27 PM
Basic electrical question honest-al Vulcan 900 3 08-05-2013 11:36 AM
Basic Oil Change Questions Martini Man Vulcan 900 22 09-26-2009 04:57 AM
Basic Oil Change Questions Martini Man Oil and Lubrication 34 09-15-2009 06:37 AM
Could I get the answers to some basic questions please? alazar14 General Vulcan Talk 20 06-13-2009 04:57 PM
