Rear turn signal relocation - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 02-25-2017, 10:02 AM Thread Starter
Hi guys and gals,
I'm new to posting so bare with me. I have a 96 800 that I put a rear Classic fender on it and hard saddle bags. I can't use the stock turn signals as there is no room. Any suggestions on turn signals that mount on the fender without major modifications.
Thanks in advance, Ed
ejacko is offline
post #2 of 7 (permalink) Old 02-25-2017, 10:48 AM
BOTSpring Winner 2017
Shores's Avatar
Year/Make/Model: 1995
Displacement/CC's: 800
Color: Gold
What about stick on LEDs attached to the hard bags. I've seen some great ones.
Motorcycle LED Lighting by Custom Dynamics
Shores is offline
post #3 of 7 (permalink) Old 02-25-2017, 10:55 AM Thread Starter
Thanks for the reply. Problem is I mounted the bags with Easy Brackets so I can take the bags off if I wanted to ride without them.
ejacko is offline
post #4 of 7 (permalink) Old 02-25-2017, 11:28 AM
GaHack1's Avatar
My Viking bags had a new tag bracket with mount for the turn signals.
https://www.vikingbags.com/motorcycl...saddlebags.htm
1996 VN800A
GaHack1 is offline
post #5 of 7 (permalink) Old 02-25-2017, 12:02 PM
You can search tali light relocation on this site.
VN800 Turn signal relocation (post 1 of 2 - pics galore!) - Kawasaki Motorcycle Forums
If you look on the net I'm sure you can buy a bracket from a place like cruiser customs.
Ron M is offline
post #6 of 7 (permalink) Old 02-25-2017, 08:38 PM Thread Starter
Thanks guys,
I appreciate the suggestions. When I figure out which way I'm going with this I'll post some before and after pics.
ejacko is offline
post #7 of 7 (permalink) Old 06-23-2017, 09:24 PM
Year/Make/Model: 2004 Vulcan 800 Classic
Displacement/CC's: 805
Color: Blue
Vulcan 800 Classic Rear Turn Signal Relocation
I used this advice and it worked great - the parts were available through a local OEM retailer (you can also get them online - I spent ~$85 for everything I needed). Best part is that you can use the existing turn signal lights. Several minor differences with my install:
- I took the rear fender off to drill the three holes
- I extended the turn signal cables by 18 inches and wrapped the extra under the seat (cable routing was the same by using the existing brake light cable on the underside of the fender)
- I added locktite to the bolts that held the turn signal mount to the fender
smittysfishn is offline
Rear turn signal relocation pics and ideas chi Vulcan 800 9 03-27-2016 10:12 AM
Rear turn signal relocation. Texas_Jack Vulcan 2000 11 11-23-2014 02:55 PM
800A rear turn signal relocation ideas? cappugliese Vulcan 800 1 03-22-2013 04:41 PM
Turn signal relocation ideas for 800A Stryker777 Vulcan 800 14 04-25-2011 02:26 PM
Replacing Right Front turn signal and Left Rear turn signal qxinfinity Vulcan 750 0 11-03-2010 04:02 PM
