radiator flush engine flush - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 24 (permalink) Old 02-14-2017, 09:58 PM Thread Starter
anyone have any info about flushing the cooling system?
have a 99 vulcan 800 and I'm sure its never been done.
two years ago i drained the coolant and put in fresh, but i'm sure it could use a good douche,
like with a caustic cleaner. radiator cap needs replaced, and there is crap in the upper hoses - so I'm
sure the block and radiator itself has to have crap in it. want that out.
last summer hot light came on more often. this is Florida so no surprise, but it's been lighting up a bit more often...
1964 Yamaha 90cc - hacked up to loose weight and riden in the dirt
1981 Suzuki 450E - bought new
1983 Suzuki 1100ES - bought new
1983 Yamaha Maxim 750 - resurrected from the scrap pile
1999 Vulcan 800 - resurrected from the scrap pile
Brewster_440 is offline
post #2 of 24 (permalink) Old 02-14-2017, 11:16 PM Thread Starter
found the drain plug. 10mm right side, underneath, near the outer right of the engine.
pulled that out, no fluid flows, hmmmmm
pushed a small screwdriver up the thread holes and viola! water!! like a birth plug. dirty water, cant say its anti-freeze, just dirty rusty water,
ya, need some caustic chemicals inside this engine. maybe a new thermostat.
post #3 of 24 (permalink) Old 02-15-2017, 12:09 AM Thread Starter
Kawasaki wants $50 for a thermostat and gasket.
pulled mine. cleaned it up with simple green.
looks OK, but would still have to boil it up and see if it opens.
not going to replace for 50 bucks.
anyone know a NAPA replacement for ten bucks?
I may just remove it altogether and run without. I dont ride if it's colder than 60 degrees, which these days in Florida is about never....
post #4 of 24 (permalink) Old 02-15-2017, 04:46 AM
I did flush my cooling system last summer in a simple and classic way. Just drained the old coolant and flushed with a tap water from (and to) every hole I could find and open. Then I put everything together and filled it with clean distilled water, ran engine couple of times. Drained again, filled again (distilled water) and drained again. After some three or four such cycles I filled it with green (ready to use) aluminum compatible coolant. That's it.
P.S.
Filling up is a little tricky.
If someone needs, there's a video on YouTube how it's done by one of VN800A owners. (It's not me )
tehnis is offline
post #5 of 24 (permalink) Old 02-15-2017, 07:07 AM
Color: Black / grey
What Tehnis said.
Let the water flow out all openings.
These arent cars with heater cores and hard places to get to.
If your running hot AND you know the coolant section has crud, maybe it time for a new radiator?
That is the piece that can plug up with crud and make the engine hot.
vulcandoc is offline
post #6 of 24 (permalink) Old 02-18-2017, 12:21 AM
rick's Avatar
Try filling and adding about a quart of distilled vinegar a couple times. Let run until fans comes on, drain and repeat. Do this until water comes out mostly, if not completely clear, then fill with 50/50 antifreeze.
2005 800 classic
2012 Voyager ABS
rick is offline
post #7 of 24 (permalink) Old 02-18-2017, 11:42 AM
I would not recommend to add any vinegar or any acid type fluid to any aluminum cooling system at all. It's Your decision, but it's mostly because of the way of green coolant works. The green one contains components which have "abilities to cure" microscopic aluminum damages and even repair micro leaks. If You apply vinegar to all system, You risk to rip off that protective layer, even together with some part of system's aluminum oxide, which been there for years! Well, if You still would take risks using vinegar, in worst case, You should wash only the most problematic parts. If it's, for example, radiator, take it off and wash it separately.
tehnis is offline
post #8 of 24 (permalink) Old 02-18-2017, 02:03 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
i go to the honda car dealership that sells auto parts and buy a jug of type 2 blue 50/50 pre-mix and change it every 2 years or less
btom is offline
post #9 of 24 (permalink) Old 02-18-2017, 08:10 PM
Bike Of The Fall Winner 2017
GFISH's Avatar
Year/Make/Model: 2006 Vulcan 900 Classic
Displacement/CC's: 903
Color: Silver
Engine ice. Good stuff.
"As long as I have the voices in my head, I'll never ride alone."
2006 Vulcan 900 classic
Mustang Day Tripper seat
Cobra Light Bar
Cobra Air Scoop
Cobra short sissy bar
Cobra Lowers
Baron's front and rear pulley
Baron's Big and Nasty pipes
Leatherlyke hard bags
Blue Superbrites LED accent lights
Chrome Woo Loo Air Horn
Avon Grips
GFISH is offline
post #10 of 24 (permalink) Old 02-19-2017, 05:25 AM
Is it for aluminum engine blocks?
tehnis is offline
Flush Radiator kawman_80 Vulcan 800 13 03-26-2015 10:28 PM
1700 Nomad Radiator Flush and Refill... skyguy Vulcan 1700 3 10-18-2013 09:41 PM
Radiator Flush vulcan2004 Vulcan 500 8 10-09-2013 12:21 PM
04 Classic 800 radiator flush!!! HELP! Xc01t0nX Engine Work 10 08-05-2013 07:37 PM
Engine flush to clear oil sight window yvwi Vulcan 800 2 10-28-2010 08:11 AM
