Sprocket rattle - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 02-02-2017, 09:29 PM Thread Starter
Sprocket rattle
03 800A the rear sprocket and the part it is bolted on rattle around in the housing is this normal? If not what's needed to fix it?
Dakgu is offline
post #2 of 6 (permalink) Old 02-02-2017, 09:34 PM
Bagger_Vance's Avatar
There should be no rattling. Troubleshoot before you put your life on the line.
Bagger_Vance is offline
post #3 of 6 (permalink) Old 02-03-2017, 09:42 AM Thread Starter
Your so helpful....
Dakgu is offline
post #4 of 6 (permalink) Old 02-03-2017, 07:08 PM
Your so helpful....
What were you expecting someone to tell you? So we're magically supposed to tell you what's wrong when you didn't post pictures, you didn't elaborate, and simply said it's rattling? You probably shouldn't be anywhere near a wrench so take it to a mechanic.
post #5 of 6 (permalink) Old 02-10-2017, 11:49 PM
BOTSpring Winner 2017
Shores's Avatar
Year/Make/Model: 1995
Displacement/CC's: 800
Color: Gold
What first comes to mind is were the hub dampers left out when the wheel was put back on? Also, jack the rear up and turn the wheel to see if you can create the problem. Any cracks in the hub? Check out the link below. Is this forum for helping or insulting?
http://www.kawasakipartshouse.com/oe...ar-wheel-chain
Shores is offline
post #6 of 6 (permalink) Old 02-13-2017, 09:00 AM
rick's Avatar
I agree with Shores above. 92160 are the dampers he mentioned. Also check the nuts that hold the sprocket on for tightness.
2005 800 classic
2012 Voyager ABS
rick is offline
rear drive sprocket khgiese Vulcan 900 5 08-15-2009 11:22 AM
Newbie here with drive sprocket and front fork questions. motoleo Vulcan 500 0 07-26-2009 07:45 PM
Front Sprocket Problems? bluekawman Vulcan 900 2 06-19-2009 12:35 PM
Sprocket udgrade to change gear ratio VN800 HT Vulcan 900 2 12-15-2008 04:59 PM
rear sprocket Netty Wanted to buy or trade Items 0 08-31-2008 01:49 PM
