High Flow Fuel Inlet - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 01-31-2017, 02:42 PM Thread Starter
I did the Grampsize/Scooterize deal with my 800.
have a K&N filter, 170 main jet, changed metering rod, remove baffles in the mufflers,
and have 1-3/4" exhaust (yes, removed the 1" exhaust inside the outer 1-3/4" pipes then heat wrapped them).
Bike runs nice, BUT, at about 70-75 MPH the bike wants more gas than can flow into the carb (stock plastic nipple), so I need a larger (brass) nipple.
anyone know the biggest i can find? still wants to be 90 degree, but larger than 1/4" hose. I see 5/16" is out there. any larger like 3/8" ??
1964 Yamaha 90cc - hacked up to loose weight and riden in the dirt
1981 Suzuki 450E - bought new
1983 Suzuki 1100ES - bought new
1983 Yamaha Maxim 750 - resurrected from the scrap pile
1999 Vulcan 800 - resurrected from the scrap pile
Brewster_440 is offline
post #2 of 10 (permalink) Old 01-31-2017, 08:28 PM
GaHack1's Avatar
Not an expert but I think the float needle seat would be a much smaller opening than the elbow/fuel line.
1996 VN800A
GaHack1 is offline
post #3 of 10 (permalink) Old 01-31-2017, 09:57 PM
How do you know that?
sfair is offline
post #4 of 10 (permalink) Old 02-04-2017, 06:37 PM Thread Starter
agree.
needle seat is the limiting factor to how much fuel will flow into the carb - i'm just increasing to available fuel
to flow. larger fuel demand (larger jets) needs more volume of fuel available.
post #5 of 10 (permalink) Old 02-04-2017, 06:40 PM Thread Starter
at 4,500 rpm and 75 mph bike feels like it's running lean.
I may change the main needle position up a notch so the main flows more fuel at half throttle,
but going to increase the fuel available to flow to the carb first.
post #6 of 10 (permalink) Old 02-06-2017, 06:09 PM
GaHack1's Avatar
GaHack1 is offline
post #7 of 10 (permalink) Old 02-07-2017, 01:34 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
sorry but i got lost reading #1 post on words like metering rod and nipple and would help if there was standard parts terms, and i am also lost on you needing more fuel and yet you have a 170 MJ?
btom is offline
post #8 of 10 (permalink) Old 02-07-2017, 02:04 PM
Originally Posted by btom View Post
words like metering rod ?
A Rochester/Carter term.
sfair is offline
post #9 of 10 (permalink) Old 02-07-2017, 08:51 PM Thread Starter
yes, lol, that's true. had a pair of carters on my hemi.
and rebuilt plenty of Rochester carbs.
post #10 of 10 (permalink) Old 02-07-2017, 09:03 PM Thread Starter
Kawasaki calls the metering rod a "needle-jet"
Part #16009 in this diagram:
1999 Kawasaki VULCAN 800 CLASSIC (VN800-B4) Carburetor | Babbitts Kawasaki Partshouse
the needle is tapered and the further it is pulled out of the jet then the less restriction, and more fuel flows.
stock main jet size is 130 i believe, 170 flows more fuel.
and the nipple is the pressed in fuel inlet that your fuel hose from the tank runs to.
Jetting help high flow intake Vulcan8642 Vulcan 800 10 07-16-2016 07:04 AM
Fuel tank/fuel flow bultaco4ever Vulcan 1500 13 08-14-2013 01:38 PM
High flow air filter and performance upgrade questions spideyboone Vulcan 900 10 06-21-2013 12:34 PM
Fuel Inlet 1988 VN1500A2 pmv2682 Vulcan 1500 0 03-04-2013 03:10 AM
Carb Inlet elbow insnecky Vulcan 800 9 06-06-2012 08:20 PM
