Need to replace a fork spring - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 12-23-2016, 01:10 AM Thread Starter
Hi!
Simple question: what should I consider when buying progressive fork springs? One of my springs is damaged and should be replaced. I can not find any (only one) ordinary spring, therefore I think about new progressives.
Actually, I'm looking at WIRTH right now, because of affordable price. I do not need super-duper performance. I just need a replacement for a bent spring. What are my options?
Thank You!
P.S.
On a wirth-federn.de homepage I found WIRTH FORK SPRINGS 2064 WITH ABE f. HON CBR 1000 F, KAW VN 800 A
Will I need to change and look for different spacers/washers or leave the stock ones? Seems like the kit includes only springs (?) I also can not find any info of such spring free length.
tehnis is offline
post #2 of 6 (permalink) Old 12-23-2016, 07:53 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
can you buy progressive fork springs from usa ?
btom is offline
post #3 of 6 (permalink) Old 12-23-2016, 10:19 AM Thread Starter
Hi, btom! Happy Holidays!
Sorry, no, because of import and shipping charges The springs will cost too much for me at the end.
tehnis is offline
post #4 of 6 (permalink) Old 12-25-2016, 11:50 AM Thread Starter
Well, that's it.
Ordered those WIRTH. Will be delivered next year
tehnis is offline
post #5 of 6 (permalink) Old 01-09-2017, 08:27 AM Thread Starter
Hi there!
Today I received my fork springs. They are just springs and nothing else in the kit. It turns out that nothing else is needed. The spring length is almost same as stock (46,96 cm stock vs 47 cm) Spacers and washers should be taken from a stock configuration. All I need to do is to pour off 30 ml of oil from each fork rod.
Yuppee! A spring with new springs
tehnis is offline
post #6 of 6 (permalink) Old 01-09-2017, 12:05 PM
btom's Avatar
congratulations on your new springs
btom is offline
Fork lock: I need to replace a bolt. TrainingWheels Vulcan 1500 10 09-14-2017 09:53 AM
Replace fork oil V900? crazyj Vulcan 900 0 06-17-2016 02:47 PM
Fork lock - Impossible to replace? Vulcan_Demon Vulcan 900 0 03-09-2016 07:07 PM
replace fuel petcock spring boxer15 Vulcan 800 4 01-26-2015 09:07 PM
Fork Seals: Replace or just a symptom? vulcan500_81005 Vulcan 500 3 10-22-2012 10:25 PM
