Vacuum sealing petcock trash switch to manual - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 11-01-2016, 10:55 PM Thread Starter
Alviar67's Avatar
Year/Make/Model: 98 vulcan 800
Color: Pearl white
Ok so i have a 05 800 and was having problems with it getting fuel the filter wouldnt fill back up so id "run out of gas" so id pull over and would have to swith it to pri so it would work. After it got to where my bike wasn't getting fuel at all i flipped through different post on here and looked at countless videos on YouTube and through some careful fiddling and blind guessing i figuerd the vacuum release on the oem petcock wasent releaseing. I took the petcock apart a few times to clean it and decided to take out the vacuum sealing part and put it back on my tank. And vuola it leaked a crap ton of gas. So i fumbled through some more post and watched more videos and saw one saying you could use a suzuki lt80 manual gravity feed petcock it fits perfect. Looking at the petcocks on there i saw that it is exactly like the one on my big Bear that i already purchased a few month back. So i decided to give it a shot along with useing more hose and a better filter it works amazingly. So to make a long storry short switch to a manual petcock with a shutoff valve it will help you out in the long run.
Alviar67 is offline
post #2 of 4 (permalink) Old 11-02-2016, 05:29 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
the '05 800 already comes stock with a manual petcock with a shutoff valve, so I don't understand what you have done or working with, and what's with the filter? is that something you added?
btom is offline
post #3 of 4 (permalink) Old 11-02-2016, 06:49 AM Thread Starter
Alviar67's Avatar
Color: Pearl white
The petcock that was on the bike worked of a vacuum that ran from the side of it to a vacuum pump in the carb and only had on pri and res no off position on the switch. The air filter was on the bike when i bought it along with other pictures ive seen and vidoes ive watched with them. So unless its common for people o put those on there then im guessing it comes with it.
Alviar67 is offline
post #4 of 4 (permalink) Old 11-07-2016, 12:00 PM
NEvulcan's Avatar
Year/Make/Model: 2000 Vulcan Classic
Color: Black/White - Custom Paint
Sounds like this is one of the 'upgrades' made in the 800 series. I have a 2000 vn800B and it also has a vacuum fed petcock (Run-Pri-Res) I'm not sure what year they stopped using that style petcock but it sounds like they did on the 2005's. They may have been testing the new petcock on the 2005 800's before making it standard on the first year of the 900's in 2006.
Anyone else have an 800 from 2001-2004 with a gravity fed petcock?
Current stock:
2011 Vulcan Vaquero
2000 Vulcan Classic (800) - Bobber
1978 GS750
NEvulcan is offline
Petcock to Carb Vacuum Line Meatluft Vulcan 800 6 06-15-2015 03:48 PM
Petcock Replacement, (Not Vacuum) MnSpring Vulcan 800 1 09-07-2014 11:05 AM
Vacuum Petcock From Hell - Recommend a good manual valve? Phreon Vulcan 500 10 09-09-2013 10:48 PM
Dreaded vacuum petcock - Mine's dripping Phreon Vulcan 500 11 07-03-2013 03:41 PM
Is there a way to switch to a manual petcock BlackSpanker Vulcan 500 8 12-31-2009 11:49 AM
