'97 VN800A bog/backfire - mixture adjust? - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By gtrdave43
post #1 of 7 (permalink) Old 08-18-2016, 09:53 PM Thread Starter
Year/Make/Model: 1997 Kawasaki Vulcan
Displacement/CC's: 805
Color: Red
Okay, for some background, check this thread:
https://www.vulcanforums.com/forums/5...e-w-video.html
I tightened the clamps for the hose between the carb and intake and that solved the issue I had mentioned in that thread, but the bike has never really run as smooth as it did when I first bought it several months ago.
The main problems now are a hesitation or bog at low throttle...and sometimes it just dies, but quickly restarts...and a backfire and burble on deceleration, which it never did before.
Is it possible that it's running too rich? Or too lean? Or...?
I did mess with the idle speed adjust a couple weeks ago, but that shouldn't cause the above issues I'm describing.
I'm open to suggestions and I can make a video over the next few days if it will help.
gtrdave43 is offline
post #2 of 7 (permalink) Old 08-19-2016, 01:02 AM
Well, there's one more thing that still comes on my mind. Did You check Your carburetor Air Cut-Off Valve? The simplest reason for deceleration backfire sometimes is a damaged membrane or stuck valve. Sometimes it gives the backfire also on a cold engine start and acceleration.
P.S.
ACV-401 VN800A | eBay
tehnis is offline
post #3 of 7 (permalink) Old 08-19-2016, 06:06 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
so when you bought it until now, (besides the boot clamp bolts tightened up), was any changes done to the carb? or did you add a new set of pipes? new airbox?
btom is offline
post #4 of 7 (permalink) Old 08-19-2016, 07:14 AM Thread Starter
Color: Red
No, it's exactly as purchased.
post #5 of 7 (permalink) Old 08-27-2016, 01:28 PM Thread Starter
Color: Red
Is it possible that I overtightened the carb-manifold hose?
I've read where doing so can cause an air leak? So, maybe I fixed one bad air leak only to create a smaller one?
post #6 of 7 (permalink) Old 08-27-2016, 04:51 PM
btom's Avatar
if you are in 1st gear and on acceleration to 2nd the bike hesitates that's a sign you need to open up the pilot mixture screw counter clock-wise, another indication is on deceleration from speed (closing throttle) and the motor backfires thru exhaust pipes, you need to remove the air entering the reed valves to the exhaust ports, you do that by removing gas tank and removing the epa air valve and tube going to both front and rear cylinder reed valves that are inside both cylinders, the epa air valve lets in fresh oxygen to the exhaust pipes to burn off any unburnt gas mixture entering the pipes
btom is offline
post #7 of 7 (permalink) Old 03-24-2017, 10:00 PM Thread Starter
Color: Red
An update:
Also, HUGE NEWS: I discovered why my bike was running so badly.
The dual clamp around the hose that mates the carb to the intake manifold? Well, one side got over tightened and worked its way off the hose, causing the hose to be misaligned with the intake and letting in gobs more air than should have been allowed.
I'd read about this very thing, but didn't suspect anything because I couldn't see the bottom of the hose and clamp UNTIL I removed the carb and hose.
I wondered why the ends of the two sides of the clamp were at different gaps when supposedly tightened.
I just reassembled everything and started the bike.
OMG! The thing started right up with no hesitation and bogging and idled perfectly even after sitting for 2 weeks in the cold.
Kiddrock24 likes this.
97 vn800a GoMeatCube Vulcan 800 24 06-17-2017 11:52 AM
'97 VN800A rough start/idle - w/ video gtrdave43 Vulcan 800 10 07-25-2016 01:58 PM
air/fuel mixture adjust vulcan 900 andrei00y Vulcan 900 0 08-02-2012 10:41 AM
Can I adjust mixture screw w/carb on bike??? davemn Vulcan 800 13 03-28-2011 06:17 PM
How to adjust Headlight? 2000 VN800A lightningfish General Vulcan Talk 1 02-06-2009 09:43 PM
