What tire psi should I use? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 08-05-2016, 11:38 AM Thread Starter
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
'05 800 Michelin Commander II tires front and rear.
Solo rider 165 lbs, no luggage.
I still don't know what psi I should set both my tires at. What tire pressure are you guys using?
btom is offline
post #2 of 11 (permalink) Old 08-05-2016, 11:59 AM
My book states 28 I think, I was lax last year checking my pressure and worn out front tire was result. I check every few days now and run and even thirty in front and back.
8hundred is offline
post #3 of 11 (permalink) Old 08-05-2016, 12:02 PM
Look n the side of the tires.
I ran 32 front 36 rear solo. I don't think 36 on both will hurt.
Ron M is offline
post #4 of 11 (permalink) Old 08-05-2016, 01:02 PM
l1ranger's Avatar
Year/Make/Model: 2015 Vulcan Custom
Displacement/CC's: 900
tires should have a max psi rating - and there is a plate on the frame near the front tire of my custom that lists the psi for front and rear - i belive mine is 40 front and 32 rear
Riding is therapy...Riding with friends is group therapy
Josh
l1ranger is offline
post #5 of 11 (permalink) Old 08-06-2016, 12:28 PM
soyarm's Avatar
Year/Make/Model: 2002 Vulcan Nomad
Displacement/CC's: 1500
Color: Burgandy/Silver
I have a Nomad and the recommendation is just to opposite of that stated. You may have those reversed or just different bikes configurations.
soyarm is offline
post #6 of 11 (permalink) Old 08-16-2016, 01:42 PM
Wow, I have Pirelli Route 66 tires on my 05 800, and my motorcycle mechanic told me 34/36 F/R. Same for my wife's bike, a 2000 Honda Shadow 600 with the same type of tire.
10k on 6-yr old tires, they still grip OK - not great, but OK.
-John
DraKhen99 is offline
post #7 of 11 (permalink) Old 08-17-2016, 08:04 AM Thread Starter
btom's Avatar
what I did on the Michelins is go 36F/38R, and I think I am pleased because my 15 mile ride on that yesterday went really good, I liked the feel, and I find that the tubes stopped leaking bits of air when I started using those metal valve caps I bought, the ones with the value stem remover prongs on the ends, also my new tire pressure gauge I got at NAPA is working out just great too, I now have 5 gauges and only this NAPA one works the way I like
btom is offline
post #8 of 11 (permalink) Old 08-18-2016, 08:11 AM
Color: Orange SE
The number printed on the sidewall is a do-not-exceed pressure when the tire is cold. With the tires aired up that much, the wear will be the least, because the tires will be stiffer and have less contact patch.
Lots of guys run that because they don't really ride very hard (and neither do I), and they are mostly concerned with tire wear.
My personal opinion is to start with the recommendation on the sticker (found under the seat on the rear fender usually, with a copy in your manual) and adjust from there. Lower pressures will provide a more supple ride, improve handling, improve suspension, and improve braking and wet weather performance. Higher pressures will increase tire life. Find yourself a good balance. On my Vaquero, I run what the sticker says and find the bike handles great at that pressure.
Romans5.8 is offline
post #9 of 11 (permalink) Old 08-19-2016, 10:13 AM
Originally Posted by Romans5.8 View Post
With the tires aired up that much, the wear will be the least, because the tires will be stiffer and have more contact patch.
Ooops, I think you meant less contact patch, correct?
sfair is offline
post #10 of 11 (permalink) Old 08-19-2016, 10:23 AM
Color: Orange SE
Oops, typo! Yes of course, LESS contact patch.
Is 0.5 psi loss on rear tire in 48 hrs ok? btom Vulcan 800 7 08-17-2016 08:17 AM
Front Tire Pressure - Rate of Lost PSI Romper Vulcan 900 13 04-01-2015 03:23 PM
tire psi? what y'll running? Bridgette Vulcan 1500 15 05-04-2012 11:32 PM
When should I REALLY change the oil and what to use hailrazer Vulcan 900 15 10-20-2010 08:32 AM
What engine oil should I use? vulcanologist Vulcan 1500 2 05-28-2010 01:02 AM
