tire pressure for Michelins - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 07-17-2016, 05:36 PM Thread Starter
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
'05 800 classic, new Michelin Commander II tires front and rear, solo rider, what PSI should I put them at?
btom is offline
post #2 of 7 (permalink) Old 07-17-2016, 05:59 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Would set them at whats the mfg recommends ,set my BS 32 fr,36 back,was at cold psi
revrider is offline
post #3 of 7 (permalink) Old 07-17-2016, 06:48 PM Thread Starter
btom's Avatar
ok, I went looking for mfg recommended pressure and found it on a label on the chain guard, 28 front/28 rear
thanks
btom is offline
post #4 of 7 (permalink) Old 07-17-2016, 08:24 PM
revrider's Avatar
thanks
NP,Set mine couple lbs higher,feel squishy to me at mfg specs,It's also on the tire
revrider is offline
post #5 of 7 (permalink) Old 07-18-2016, 12:18 AM Thread Starter
btom's Avatar
ok I went looking for mfg specs again this time on tires, says
front Michelin max load 805 lbs @ 42 psi cold,
rear Michelin max load 908 lbs @ 42 psi cold
28/28 might be squishy at bike mfg specs
I've seen some posts they're doing 40/40
that could be with 2-up and luggage and they're also heavier bikes than my 800 and I'm only 5'7" 165 lbs and not doing 2-up
I should do couple lbs higher like yours @ 32F/36R cold
btom is offline
post #6 of 7 (permalink) Old 07-20-2016, 05:29 PM Thread Starter
btom's Avatar
well I was about to go for a ride and noticed that the rear tire is flat, no air in the tire whatsoever, my bike has not been moved since I checked air in the tire on Monday, all I did to the tire was on Monday use my digital gauge to check the air pressure, it was 36.5 psi, I also noticed that the metal stem on my digital gauge is out of line and doesn't seem straight, Do you suppose when I used that gauge it caused the valve stem on my tube to stay open? the air in the tire was fine since I had a new Michelin installed 3 months ago by a bike shop, I took the wheel to them and reinstalled the wheel myself.
btom is offline
post #7 of 7 (permalink) Old 07-20-2016, 05:40 PM
revrider's Avatar
Possible,try removing core and then put it back in?is a core remover,just spins out
revrider is offline
Michelins New Airless Tweel Tires Inkydoggy Wheels and Tires 1 11-26-2014 04:53 PM
900 Custom Tire Pressure ???? ScottyJ Vulcan 900 13 09-25-2014 11:53 AM
Michelins Commander 2 Backordered jp58 Vulcan 1700 40 09-19-2012 06:15 PM
Thinking of Designing an Oil Pressure adapter for oil pressure and temp gauge bikeman2011 Vulcan 900 1 04-20-2011 05:01 PM
Scraping Pipes, Synthetic Oil, Tire Pressure CruisingEagle Vulcan 2000 2 07-13-2008 07:20 AM
