Backfiring through carb - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 27 (permalink) Old 07-12-2016, 04:48 PM Thread Starter
Year/Make/Model: 98 Kawasaki Vulcan classic
Displacement/CC's: 800
Color: Black
96 vn800
Mods- intake, intake ports cleaned up on the heads(nothing crazy) cobra pipes and EPA delete
Jetting is 52/175
Idles ok, backfires through the carb with light throttle.I would think it's a lean condition, but it dies on the choke. Pulls pretty good at wot. Any ideas
94ltz is offline
post #2 of 27 (permalink) Old 07-12-2016, 06:05 PM Thread Starter
Color: Black
Update, I turned the idle screw in to 1 1/2 out, was alittle better. Backfiring went down a little. So then I turned it to 1 1/4 out backfiring was a little worse
94ltz is offline
post #3 of 27 (permalink) Old 07-12-2016, 06:23 PM
Vulcan8642's Avatar
Year/Make/Model: 1998 kawasaki vulcan
Color: Black
Put 2.5 turns shim needle going through same thing
Vulcan8642 is offline
post #4 of 27 (permalink) Old 07-12-2016, 06:25 PM Thread Starter
Color: Black
I'll give it a try and see what happens. What jetting are running, the same as I have
94ltz is offline
post #5 of 27 (permalink) Old 07-12-2016, 06:29 PM
Vulcan8642's Avatar
Color: Black
Yes 52 pilot 170 main cut the air box I couldn't get the bike to take any throttle stock needle shimmed with number 4 washers from lowes
post #6 of 27 (permalink) Old 07-12-2016, 06:30 PM Thread Starter
Color: Black
Ok cool thanks
94ltz is offline
post #7 of 27 (permalink) Old 07-12-2016, 06:59 PM Thread Starter
Color: Black
It doesn't like 2 1/2. I have two shims and about 1 3/4 out runs perfect, but as soon as I go to put it on choke it dies
94ltz is offline
post #8 of 27 (permalink) Old 07-12-2016, 10:24 PM
andyvh1959's Avatar
Year/Make/Model: 2003 Vulcan VN1600 Classic
Displacement/CC's: 1600
Color: Pearl Ivory
First off, is it really backfiring through the carb? True backfiring, especially on bikes with electronic ignition, is very rare. True backfiring is either caused by a valve timing issue or by the ignition being so far out of proper setup that the spark plug fires when the intake valve is open and ignites the incoming air/fuel mix before the intake valve is closed. So in this case "backfiring" is probably not the issue.
With the mods you made, I bet what you hear is exhaust popping due to a lean fuel to air ratio on closed throttle on decel (light throttle). On way to know for certain, next time you hear the popping pull in the clutch. If the popping stops immediately, then you have proof it is not backfiring. Decel popping causes no harm at all to the engine, but a modded exhaust will cause the popping noise to be more evident. Turning the idle screw only slightly keeps the throttle plate slightly more open on decel and adds air to the mix, slightly reduces the vacuum through the venturi and reduces the fuel draw.
andyvh1959 is offline
post #9 of 27 (permalink) Old 07-13-2016, 11:18 AM Thread Starter
Color: Black
It does it without moving too. Not as much. I turned the screw in and it doesn't pop as much. I noticed yesterday when I took it out, I did wot for a couple gears felt pretty good. When I let off and and went to ride slowly it popped a little bit. Still won't run on choke. I might try and put the 50 back in
94ltz is offline
post #10 of 27 (permalink) Old 07-13-2016, 11:21 AM Thread Starter
Color: Black
Also if I put it at 1 1/2 the popping is worse but it will some what run on choke. 1 3/4 runs better but won't run on choke. It kinda has me a little confused
94ltz is offline
Petcock failure gas pushing through carb Fastboat Vulcan 800 23 05-12-2018 07:28 PM
blow back through carb 94ltz Vulcan 800 4 10-08-2016 02:40 PM
backfiring through carb cruiserron New Member Introductions 2 02-04-2014 06:25 PM
backfiring thru the carb bamadrive Vulcan 800 11 05-29-2011 07:20 AM
1700 Classic backfiring through intake gvrider Vulcan 1700 27 04-30-2011 11:40 PM
