Coolant in oil - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 07-11-2016, 09:16 PM Thread Starter
oldrockr's Avatar
Coolant in oil
Hello, I have a 1996 VN800A with a newer engine. There are approximately 10,000 miles on the engine. I have an overheating problem, and it appears that coolant has been getting into the oil. Is there a way to locate the problem before disassembling the engine? Also, could this be related to a valve adjustment 1000 miles prior to the trouble?
Thanks,
Doug
'96 VN800A
V & H Cruzers
F & S Sissy Bar
Unik Fork Bag
oldrockr is offline
post #2 of 3 (permalink) Old 07-11-2016, 09:42 PM
Hot Cruiser's Avatar
Usually coolant in engine oil is due to a head gasket problem. Shouldn't be related to a valve adjustment procedure since that doesn't require removing cylinder head bolts unless that is needed to adjust the valves on the 800, which seems unlikely. Suggest re-torqueing the cylinder head bolts to see whether that solves the problem. I found those bolts on a previous bike to be under-torqued, which caused an oil leak.
Jesus is Lord
Hot Cruiser is offline
post #3 of 3 (permalink) Old 07-12-2016, 11:09 AM Thread Starter
oldrockr's Avatar
Thanks for the tip. I'm suspecting a head gasket, too. I wish there was a way to determine which cylinder is faulty.
Doug
'96 VN800A
V & H Cruzers
F & S Sissy Bar
Unik Fork Bag
oldrockr is offline
Water/Coolant? in my Oil! Texas_Jack Vulcan 2000 14 02-26-2016 09:54 PM
Coolant checking and oil Jels Vulcan 500 12 04-06-2014 10:20 AM
Much needed maintenance... Plugs, coolant, oil, etc... atineo1982 Vulcan 900 8 03-27-2014 07:38 PM
No coolant out the coolant drain plug?!?! WildMan Vulcan 800 21 12-16-2013 11:35 AM
What synthetic oil, and what coolant RoninSpecter General Vulcan Talk 15 04-03-2013 09:09 PM
