800 carb problem? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 1 (permalink) Old 06-12-2016, 04:17 PM Thread Starter
Unhappy 800 carb problem?
Hello guys from occasionally sunny Scotland .I have been rebuilding an 06 800 for a while now .Fitted a replacement motor with my original carburetor .I had cleaned the carb before fitting .Had the fuel leaking from the firstly jet holes .Thought float /needle valve ,dirt problem .I stripped carb again thoroughly cleaned it changed needle valve even though it looked ok . checked float height .Fitted again bike will start and run on choke ok when I put the choke in it will run but eventually fuel starts leaking If I rev the engine it turns into a flood of fuel .I obviously suspected a float problem .Carb down again cleaned again changed float .Fitted checked float height .Same again I have rebuilt the petcock even though it seemed ok .I am kinda at the end of my rope with this .Any ideas on where I am going wrong ?
daytona12 is offline
Carb Cleaning: What to Dip and Is Carb Repair Kit necessary? rileyyh Vulcan 500 9 05-13-2016 07:41 PM
Carb problem on my '01 1500 Rustyhammer Vulcan 1500 1 09-01-2010 02:05 PM
1500 carb problem........need help. richw40 Engine Work 6 05-16-2010 10:27 AM
carb problem? eviltwinjames Vulcan 800 11 04-30-2010 12:32 PM
Trash problem in carb SgtWilliam Vulcan 1500 2 04-23-2010 02:23 PM
