New Shinko 777 HD Front Tire Rubbing Fender - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 06-10-2016, 09:36 PM Thread Starter
Year/Make/Model: 1999 Vulcan Classic
Displacement/CC's: 800
Color: Custom Paint
Has anyone had any problems using a Shanko 777 HD 130/90 16 on a Vulcan 800. My first Shanko tire sidewall gave out under 500 miles and they replaced it for free. Well my first ride with the new tire was only about an hour long and when I parked, I could hear the tire rubbing the front fender. I was told the tire rep. wanted to ordered another Shinko tire from a different warehouse to make sure it wasn't a bad lot. Again I took a short ride and the tire was rubbing the front fender. The rim was checked out when they change the last tire. It just seems like the Shinko tire runs wider then 130mm. Now they are ordering me a Dunlop tire to try. Also, I was wondering if the first tire was rubbing and that is why it only lasted a couple hundred miles.
Brian PA is offline
post #2 of 6 (permalink) Old 06-11-2016, 02:48 AM
rick's Avatar
I take it this is on a classic? I have the same tire on my 05 800 classic and have not noticed this rubbing, but now i'm going to check that in the morning.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 6 (permalink) Old 06-11-2016, 06:19 AM Thread Starter
Color: Custom Paint
Yes, it's a classic. How much space do you have between your tire and fender? This morning I flipped the fender bracket to see if it was bent and still had the same problem.
Brian PA is offline
post #4 of 6 (permalink) Old 06-11-2016, 09:32 AM
rick's Avatar
Sorry, I was wrong. I have a Meztler 880 on the front of the 800, I have the Shinko on the front of the Voyager. The Metzler has maybe 1/16" clearance on each side of the fender bracket, its a tight fit. I'll try to get a measurement of the tires later on though.
2005 800 classic
2012 Voyager ABS
rick is offline
post #5 of 6 (permalink) Old 06-11-2016, 02:44 PM Thread Starter
Color: Custom Paint
Rick,
Sounds like a tight fit might be normal for the 800's front tire. My friend has a nomad and I can fit my fingers between the tire and fender.
I might give it a couple of rides and see what happens.
Thanks for your reply,
Brian
Brian PA is offline
post #6 of 6 (permalink) Old 06-30-2016, 08:27 PM Thread Starter
Color: Custom Paint
Tire update.....they installed a pirelli tire and there is almost a 1/2 inch gap between the tire and fender, no more rubbing.
Brian PA is offline
Shinko 777 tread direction msal Wheels and Tires 11 10-07-2015 05:09 PM
Shinko 777 Whitewall Rear Tire syfdawg Vulcan 1700 3 08-03-2014 09:08 PM
Front tire rubbing dwhit Wheels and Tires 16 04-30-2014 10:53 AM
Shinko WW 777 at Beach gcsteve Vulcan 1700 24 10-25-2012 03:37 PM
90/90 Metzler 880 rubbing on front fender Heretic Vulcan 900 21 03-25-2012 09:10 AM
