Petcock Question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 05-07-2016, 06:39 PM Thread Starter
Petcock Question
Mine stated leaking recently so I have taken it completely out and today ordered a kit off ebay to repair it. While packing it away until parts arrive I noticed a green residue coming out of the hole in the side of the valve, it looks like crumbled chalk. I think it is coming from inside the screen that goes into the tank and would have a straight shot into the carb. I can see a little green tube or something inside the screen and the screen looks like its made into the petcock, I would not want to replace it without taking care of this. Has anyone experienced this or know a way to replace it without buying a new petcock? Thanks
8hundred is offline
post #2 of 9 (permalink) Old 05-08-2016, 12:47 PM Thread Starter
I kept bumping the petcock until the crumbly green stuff basically stopped and have ordered a filter for the line. I took the back cover off and the little silver plate on top of the gasket is very fragile, how do I get it off? I tried gently pulling on it and it won't budge, any ideas? thanks
8hundred is offline
post #3 of 9 (permalink) Old 05-08-2016, 02:59 PM
GaHack1's Avatar
Isn't that part of the vacuum diaphragm ?
1996 VN800A
GaHack1 is offline
post #4 of 9 (permalink) Old 05-08-2016, 03:22 PM Thread Starter
Yes, I tried to locate a you tube video and the ones I watched were all different. I tried pulling on it with a small pair of pliers but it wouldn't budge, so I decided to stop until I could get good info.
8hundred is offline
post #5 of 9 (permalink) Old 05-08-2016, 03:25 PM
Those fuel taps are one of the items that it is more cost effective to just replace the whole unit than fool around with them.
The rebuilds are hit and miss, with more misses being the norm.
Most folks just replace and be done with it.
sfair is offline
post #6 of 9 (permalink) Old 05-08-2016, 05:33 PM Thread Starter
I just tugged on it and it popped out, since I have ordered the kit I will give it a try, if it fails will order a new one. thanks
8hundred is offline
post #7 of 9 (permalink) Old 05-08-2016, 10:46 PM
rick's Avatar
Just new petcock last winter for me 800, got it from Partzilla, cheapest by for.
2005 800 classic
2012 Voyager ABS
rick is offline
post #8 of 9 (permalink) Old 05-09-2016, 06:15 AM
Year/Make/Model: 2001 Vulcan 800 Classic
Displacement/CC's: 800
Color: Red
I see you got it out now, but just for the record...
When things are stuck on your bike, I've learned 2 ways to fix it.
If it's metal on metal (no rubber/plastic/vinyl/leather nearby) WD-40 is your pal.
If there is anything involved that is not metal or is ultra delicate and you're worried about WD-40 being too abrasive, go grab a bowl from the kitchen, dump a few tablespoons of dish soap in it, and fill it up with the hottest water you can stand. Grab a rag and start with some gentle soaking. Get firmer from there, but take your time.
The soap acts as lubricant and the heat is a natural method of cleaning off grime.
Good luck with your petcock. While it's out of your tank, see if you can wipe around the inside of the tank with a towel and check for really bad residue. Wouldn't do to reassemble everything and find out later that the cause is coming from the tank.
boxfox is offline
post #9 of 9 (permalink) Old 05-12-2016, 06:16 PM Thread Starter
Well received the new petcock kit today from ebay, added an inline filter and put the kit in in less than thirty minutes, then went to get straight gas so I am happy.
8hundred is offline
Petcock Question: Is it Needed as is gusgriff Vulcan 800 10 08-05-2013 03:36 PM
Petcock Question gusgriff Vulcan 800 8 06-30-2013 10:58 PM
Petcock question talkingplant Vulcan 500 4 02-04-2012 04:11 PM
750 petcock cappy Engine Work 0 07-12-2009 08:26 PM
Wtb: Petcock For En500 MetallHed Wanted to buy or trade Items 0 04-30-2009 04:54 PM
