Chain adjustment weight on or off - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 04-29-2016, 06:02 AM Thread Starter
So I think it's time to adjust my chain tension after a couple a thousand miles on new sprockets and chain. I can't remember how I did it last tin so I read the manual and a ton of posts on the subject. Some say check the vertical play in the chain with the riders weight on the bike others say check it unloaded. Which one is it ?
bluegoose95401 is offline
post #2 of 3 (permalink) Old 08-24-2016, 03:09 PM
Weight off to allow the wheel tighter or looser. With weight the adjustments won't move. Then weight on to check the chain tension with the load.
1996 800A
gun4u2 is offline
post #3 of 3 (permalink) Old 08-24-2016, 04:13 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
set a 50 lbs bag of potatoes or carrots on the seat with bike on side-stand, use one finger on bottom return-run of chain in the middle push up and eyeball distance from no finger to finger tension, note the acceptable service manual reference for slack adjustment, I think it you can push the middle of the chain upwards more than 2 inches you're too loose
btom is offline
Spring Adjustment & weight... Vandy Vulcan 900 17 12-29-2012 12:11 AM
Bike weight vs overall weight jeff72 Vulcan 1700 1 06-24-2012 10:38 PM
chain adjustment jtaylor Vulcan 800 3 04-02-2012 12:47 PM
Chain adjustment. fishtaco Vulcan 800 2 04-17-2011 06:37 PM
Chain Adjustment nuts Stryker777 Vulcan 800 2 01-18-2011 02:48 PM
