Ignition/ Rear Tail Light Issue - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 04-28-2016, 10:54 AM Thread Starter
vn8002015's Avatar
A few months ago i laid my bike over, then after that it wouldnt start due to no spark. took it to the shop and they found out that the culprate is that some ignition wires are tied into my rear brake light harness. they tied the wires together (red/Blue) and i was then getting the spark i needed to start but now my rear break light is always on even though they are soldered into the other red and blue wires in the harness. help!
also put 4 LED strips for blinkers on my bike and when i turn one direction they all turn on. is that a flasher relay issue or whats the fix for that??
VN8001500
vn8002015 is offline
post #2 of 11 (permalink) Old 04-28-2016, 12:39 PM
If when you say ignition, you mean ignitor, it should be on its own circuit.
sfair is offline
post #3 of 11 (permalink) Old 04-28-2016, 12:43 PM Thread Starter
vn8002015's Avatar
i know thats what im thinking but its not. its tied into my rear lighting for some reason and i dont know why. your rear lighting has a connector to your main harness. part of that lighting harness for some reason is that my igniter is tied into it. Just wondering if someone has ever had this same issue or if im the only one.
VN8001500
post #4 of 11 (permalink) Old 04-28-2016, 01:12 PM
rick's Avatar
Had my brake light stay on because rear brake switch needed adjusted, may check that. As for the turn signals, the only have 1 indicater, so they probably are feeding back through it.
2005 800 classic
2012 Voyager ABS
rick is offline
post #5 of 11 (permalink) Old 04-28-2016, 01:17 PM Thread Starter
vn8002015's Avatar
ive checked that but ill take it apart and see if that is the culprate. when i didnt have to red and blue tied together my lights worked but my bike wouldnt start. idk its a funky thing. as for the tail lights ill just order an LED switch flasher relay and see if that fixs that. these are the only things keeping me from registering my bike.
VN8001500
post #6 of 11 (permalink) Old 04-28-2016, 02:25 PM
If your ignitor is tied into the tail light circuit, you have more issues than the signals.
Is this something you want to repair, or???
sfair is offline
post #7 of 11 (permalink) Old 04-28-2016, 04:11 PM Thread Starter
vn8002015's Avatar
yeah it is, im not worried about the signals at this time but yeah its something i need fixed to get registered, and i do a lot of freeway riding and so for a safety factor it would be nice to have it be working properly.
VN8001500
post #8 of 11 (permalink) Old 04-29-2016, 09:57 AM
1. What year is the bike?
2. How many miles?
3. How long have you owned?
4. Any modifications/add-ons?
5. Did you attempt to repair the no-spark condition before taking to the shop?
6. What damage/repairs were done when it was laid down?
sfair is offline
post #9 of 11 (permalink) Old 04-29-2016, 10:55 AM Thread Starter
vn8002015's Avatar
2: 28K
3: 6 months
4: straight pipes, Biltwell bars girps and throttle, bobber seat sissy bar. (nothing mechanical)
5: the first time i took it to the shop they diagnosed it and said it was my CDI. i ordered a new one changed it out still nothing so they switched out my spark cables and tracked down that wiring issue and got it starting.
6: small dent in the tank. I did break my rear break lever, and broken handlebars. thats really it
i don't think its the actuator thingy on my break pedal just cause it works when the red and blue wire are not connected together in my rear wiring harness.
VN8001500
post #10 of 11 (permalink) Old 04-29-2016, 08:07 PM
How do you know the ignitor is tied into the tail light circuit?
sfair is offline
tail light, brake light, running light not working Rider_otStorm General Vulcan Talk 6 02-02-2018 08:35 PM
Rear Tail Light Bulbs and Brake Light Modulator IndyTom Vulcan 650 S 18 01-17-2018 07:43 PM
Tail light issue?? street325 Vulcan 2000 1 10-25-2013 03:42 PM
Design or Defect -- Voyager tail light issue OverHillAndDale Vulcan 1700 15 01-28-2013 11:43 PM
New Grips, Mirrors, and new rear Kurkaykan rear signals,license and tail light. Lazlo 900 Vulcan 900 2 04-23-2012 01:19 PM
