Bike not going faster 70 mph! - Kawasaki Vulcan Forum : Vulcan Forums
 6Likes
post #1 of 65 (permalink) Old 04-19-2016, 01:13 AM Thread Starter
Year/Make/Model: Kawasaki VN 800 - 1995
Displacement/CC's: 800
Color: Black
Arrow Bike not going faster 70 mph!
Hi,
My motorcycle is Kawasaki VN800, 1995.
Recently changed oil, oil filter, sparks plugs, air filter, adjusted the valves, cleaned coil ignition cables, and cleaned carburetor.
And until it reaches 70 mph, bikes works great, it's very powerful. But, when it reaches 70 mph, it's looks like that's all she can do, is has no more potential. It looks and sounds like when it reached 110 mph last summer, only that now is 70mph.
I cleaned the carburetor, and checked for vacuum leaks.
I don't know if this might help you find the problem, but one exhaust warms a bit faster than the other, just a little bit faster.
I live in a country when it's nearly impossible to find a good mechanic near to me. Any idea would be more than helpful, thank you.
PhilbyK is offline
post #2 of 65 (permalink) Old 04-19-2016, 06:39 AM Thread Starter
Color: Black
Any idea? I am struggling here!
PhilbyK is offline
post #3 of 65 (permalink) Old 04-19-2016, 07:30 AM
chopaholic's Avatar
Shift! Sorry... not something I've had the displeasure of having happen.
PhilbyK likes this.
It either runs like a raped ape or your just flinging poo!
1998 Kawasaki Vulcan 800 Classic
chopaholic is offline
post #4 of 65 (permalink) Old 04-19-2016, 07:39 AM Thread Starter
Color: Black
Well, thank you. At least you said something!
PhilbyK is offline
post #5 of 65 (permalink) Old 04-19-2016, 07:45 AM
chopaholic's Avatar
When you hit 70 does it feel like its starving for fuel (kicking and sputtering) are you sure both cylinders are firing? and back to my original SHIFT are you hitting 5th?
All things that would cause loss of power or speed
post #6 of 65 (permalink) Old 04-19-2016, 07:46 AM
chopaholic's Avatar
I'm really leaning towards a coil or cylinder not firing. But really sounds like ignition and not fuel.
post #7 of 65 (permalink) Old 04-19-2016, 07:52 AM Thread Starter
Color: Black
No, it does not feel like it's starving for fuel. It's feels like it has no more potential.
Just like when you reach the maximum speed limit in your bike.
And yes, I hit the 5th gear.
And, I am not that sure, but I guess both cylinders are firing, because otherwise I don't know how the bike would have all that power until it reaches 70 mph, if one cylinder was not firing.
PhilbyK is offline
post #8 of 65 (permalink) Old 04-19-2016, 07:58 AM Thread Starter
Color: Black
I will add something else, maybe this will help something.
Last night I removed the spark plug cable from the exhaust side that was getting hotter a bit faster, and when I did that, the engine shut down. I tried to start it up, and it started with difficulty, and shut down immediately.
PhilbyK is offline
post #9 of 65 (permalink) Old 04-19-2016, 08:03 AM
chopaholic's Avatar
Mine didnt want to fire on 1 cylinder when I woke it up over the winter. I yanked the enrichment valve (choke) and it was hitting on one cylinder and I rolled the throttle till i heard the second cylinder cracking and popping in. then you could tell the difference. First ride it stumbled a couple times when that cylinder would miss fire. Changed plugs and yippie smooth as a babys butt again. You can definitely feel the difference by hand at the exhaust tip when its not firing.
If I were to guess I'd say same situation but its not trying to come in at all. Not saying hold her at WOT sitting in the drive way but getting the rpms up and see if she starts popping like shes trying to fire up that other cylinder. Disconnect a spark plug. if she doesnt start the shes not firing on the other cylinder. if it does start does it sound the same? reconnect does it sound the same? If so you have no spark on said cylinder.
Best help I can give from the back of the screen here.
post #10 of 65 (permalink) Old 04-19-2016, 08:05 AM
chopaholic's Avatar
Yep sounds like a coil / wire / plug aint firing or firing weak ...well to me that is.
RPMs at 70-75 mph Daniel DiMaggio Vulcan 1600 6 04-20-2016 05:49 AM
Vn800, not going faster than 130km/h? PhilbyK Vulcan 800 0 04-17-2016 12:37 AM
Backfire at 70+mph Tullster Vulcan 800 9 04-26-2012 09:48 AM
Speedomemter is out, I thought I was going faster than nil. Vulcanyoungbuck Vulcan 500 7 05-31-2011 08:44 PM
vibration, pushing hard at 70+ mph... chicagoster Vulcan 900 15 09-19-2010 03:00 PM
