Carburetor issues - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 04-08-2016, 03:02 PM Thread Starter
vn8002015's Avatar
Carburetor issues
Hey guys, little help needed! i drive a VN800 and i laid it over back in january and since then its been problem after problem. long story short its running now but its not running correctly. It has after market straight pipes on it and a forward facing air intake. Also i took off the emissions and properly covered those ports on the carb.
The problem is that the carb is leaking gas from the air intakes. went in cleaned carb and noticed float needle spring was jammed all the way down. ordered new needle put back together and still leaks in stock position, adjusted float height a couple different times and still leakes. what could the issue be?? any tips and pointers?
VN8001500
vn8002015 is offline
post #2 of 5 (permalink) Old 04-08-2016, 04:00 PM
ducatiman's Avatar
Year/Make/Model: '95 Ducati 900SS/SP
in laying the bike over.... possible existing debris from bowl migrated into the needle/seat area, causing inability of needle to make full contact and seal?
all it takes is the tiniest piece of debris in the wrong spot...the fuel level rises and rises....filling the main mixing chamber and exiting through the air correction jets (most convenient exit path)
solution...remove float/needle, use carb cleaner on a Q-tip to swab out the seat, just like doin' your ears.
While disassembled...shoot some carb cleaner into the intake rail and blow the whole fuel path out. If you do this over white paper towels, you may see the junk.
When spraying, be mindful of the rubber slide diaphragm...always a good idea to remove prior to using aggressive carb cleaners....they can distort and permanently ruin the rubber.
ducatiman is offline
post #3 of 5 (permalink) Old 04-08-2016, 06:25 PM Thread Starter
vn8002015's Avatar
OKay, i did take the carb apart and cleaned everything. (besides the diaphragm) and didnt really see anything besides discoloration. could their be something underneath the seating that could cause this? ill take it apart one more time and use a cotton swab to see if that changes anything.
VN8001500
post #4 of 5 (permalink) Old 04-08-2016, 07:20 PM
ducatiman's Avatar
the discoloration (a coating of gooped up fuel?) is perhaps your enemy unto itself
regardless, your needle and seat is not sealing, allowing carb overfilling
you are there....you are the boss
here's an example of a clean seat, though from a different Keihin carb
post #5 of 5 (permalink) Old 04-09-2016, 02:09 PM
If it leaks while sitting, fuel tap is the problem. Very common issue.
sfair is offline
Carburetor Issues!! vn8002015 Engine Work 1 04-20-2016 10:12 AM
How-To: Disassembling the Carburetor on the EN500 MetallHed Vulcan 500 23 04-07-2016 08:28 AM
VN1500A Carburetor Issues pmv2682 Vulcan 1500 0 07-27-2013 06:54 AM
Carburetor and Performance Issues am6465 Vulcan 500 8 07-16-2011 10:18 PM
How-To: Disassembling the Carburetor on the EN500 MetallHed Vulcan 500 11 07-27-2009 12:20 PM
