Air Temp Sensor Relocation - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 07-23-2013, 06:54 AM Thread Starter
Vulcan Hammer's Avatar
Send a message via AIM to Vulcan Hammer Send a message via Skype™ to Vulcan Hammer
Re: Intake Air Temperature Sensor Relocation
Is anyone still strongly advocating this mod? Are there any long-term adverse effects?
I was going to do the mod when I had a BAK and noticed that performance dropped significantly as soon as the sensor became heat soaked...probably because it was then mounted on the BAK's aluminum backing plate which became a heat sink!
However, I returned to the stock air box and put the sensor back in the original location. In the stock air box there does not seem to be such a drastic drop in performance when the bike gets warm. More noticeable, though, is the increase in decel burble when the bike is warm. I get no burble or popping until this time.
Is this because the ECU is retarding timing based on the temp sensor readings? If so, has anyone noticed a reduction in decel burble or popping after relocating the sensor?
I have a Bully/EJK, but this does not allow any timing adjustment. If the ECU on the 1700 truly shuts off fuel when the throttle is totally closed, it would seem that the only fix for some decel popping might be a timing adjustment.
I'm hoping that the air temp sensor relocation might accomplish this. What are your thoughts?
Thanks in advance!
Vulcan Hammer is offline
post #2 of 4 (permalink) Old 07-23-2013, 05:35 PM
new kawi rider's Avatar
I installed a fan switch like Racn Ray had posted. The bike never looses power now. Road in 90 degree temps in traffic. The highest the temp guage goes is barely above half. It used to go way up there and have power loss. I am running stock air box and Kams kit installed. My heat problem has been eliminated !
2010 Voyager
Scootworks 2 inch fat risers
vance&Hines slipons
Mustang Wide Touring studded
PCV
Michelin commander 2
Ipod adapter
Titanium header wrap
8 to 12.5 inch bagger windshield
Iso grips with Rays throttle mod
Chrome rear floor board covers
Kams Kit
new kawi rider is offline
post #3 of 4 (permalink) Old 07-23-2013, 07:30 PM Thread Starter
new kawi rider,
I appreciate the input, but the Air Temp Sensor in question is located in the right side air box and relates to the temperature of the air charge entering the throttle body. Based on it's readings, it is my understanding that the ECU then adjusts the A/F ratio (like a choke on a cold engine) and may affect ignition timing. It is not associated with engine overheating or coolant temperature.
post #4 of 4 (permalink) Old 07-24-2013, 01:00 AM
I was just saying I have no problems now with retarted ignition timing now that the fan can be turned on and keep the temp guage down below half way. Maybe ray will chime in and help you out.
2010 Voyager
vance&Hines slipons
PCV
Ipod adapter
Kams Kit
Intake Temp. Sensor relocation?? Ironbo Vulcan 2000 8 09-13-2012 09:07 PM
Air temp sensor relocate jp58 Vulcan 1700 33 04-24-2012 12:58 AM
air temp sensor relocated Ozburner Vulcan 1700 22 02-25-2012 05:33 PM
air temp sensor - where is it Ozburner Vulcan 1700 9 08-28-2011 09:00 AM
air temp sensor 1500 classic fi MIRTO88 Vulcan 1500 9 05-22-2009 09:19 PM
